what belt size do i need
Old Mar 27, 2012 | 11:40 AM
prelude2.2's Avatar
Default what belt size do i need
When u delete ur ac pump do u have to get a smaller belt if u do what length?
Old Mar 28, 2012 | 08:00 AM
Enzo15's Avatar
Default Re: what belt size do i need
If its on a 4th gen you should be able to go to the parts store and ask them for a belt without the AC included, that is how I got mine.
Old Mar 28, 2012 | 02:02 PM
97ludedude's Avatar
If you run a string and measure it. Give the parts store the measurement and they can match one up. For example if it is 54 inches the belt should be a 540k4. if it was 40 inches the part number would be 400k4. the k4 is how many grooves or how wide the belt is. k4= 4groove belt k6=6groove. That is how autozone and advance measure belts. o'reillys is a little different but they will know what you mean.
Old Mar 28, 2012 | 02:31 PM
allentownrep's Avatar
When I removed the ac from my H22 I used a 360K6 belt.
Old Apr 1, 2012 | 12:18 AM
prelude2.2's Avatar
whats the benefits of doing this ?? lol?
Old Apr 1, 2012 | 03:39 PM
Wing8806's Avatar
For an H22 - it's a 36" 6 rib belt
No benefits - if your ac is broken or you just don't want it, you can pull the unit and install a shorter belt
Old Apr 3, 2012 | 01:01 AM
prelude2.2's Avatar
your prb only benefit is just weight loss huh a little bit ha
Old Apr 3, 2012 | 04:49 PM
Wing8806's Avatar
Pretty much lol.
If I had to take a guess, i'd say the actual compressor weighs maybe 10lbs
19crx93
22
Aug 16, 2010 03:46 PM
fastlane2
Feb 20, 2010 07:57 PM
shyboi4u
Aug 4, 2005 03:54 PM
98 blacksh
May 9, 2005 08:53 AM
EGcivicBoy
Nov 11, 2003 05:21 PM
