arp head studs are they worth it
im just wanting other peoples opnions on the arp head studs. have anybody heard bad **** about them or good things. and say like in my case, you have a motor that has to much compression and you pulled your threads out with your head bolt. like i did today, i thought i warpped my head so i took the head off resurfaced it, gave it a valve job etc... so then i was putting the head back on the block and all H/B's tourqed down fine to 22lbs then i started to tourqe them down to 61lbs. and then it just keep on spinnin, the shittiest feeling. so i took the bolt out and the threads came with it. and the motors a ls vtec with b16 head and b16a2 pistons typer cams blah blah, and its my daily driver like about 100 miles a day. so people are the arp heads studs worth it.
EJ1 wilcox
Feb 23, 2006 03:08 PM
