2007 Civic Auto Tranny Issues! its not even thai!
Replaced the starter in my girl's civic, car started fine, then started shifting weird, now its in limp mode, CEL+Flashing D light, code P0777, which is a shift solenoid B stuck open, took everything back apart, cleaned all connectors+applied dielectric grease to them, reassembled, same issue, this is after a hard reset (disconnected battery). NO FIX. Got 12 ohms of resistance on each solenoid, checked each with direct power, all 3 went click click. I'm guessing there might be a ground near the starter I disconnected maybe? I've also been reading up and seen that Fit's had a common problem with a pressure switch located on the front right bottom of the tranny, I figure replacing that is my next step if I can't find the missing ground.
Edit: I havent been able to read the new CEL since re-installing the battery, but hell, the guy who read them wrote them on his hand for all I know he didn't even write the write the code right.
a6killa
19
Jul 21, 2013 06:02 PM
akcapr
Mar 1, 2011 07:20 PM
DarkBB4
Apr 23, 2007 10:47 AM
