96 y8 head / 2000 y7 block, what ECU do i use?
Old Mar 25, 2012 | 07:34 PM
ATLien6's Avatar
Icon2 96 y8 head / 2000 y7 block, what ECU do i use?
Before everyone tells me to search search this has been answered 100 times blah blah; take the time to understand that I'm new to the forum, just like you were once, and haven't quite got the hang of searching specifically and finding specifically the answers I'm looking for ... so with that said, I'll cut to the chase....
My car- 2000 Civic LX, Auto Tranny, Stock motor (hush! its my daily daddy father husband car)
I have a y8 head and intake manifold off a 1996 EX, both complete
Question - I know they will mate and work, my question lies in what ECU would I run, 96-98 or 99-00 P2P
Won't have to bother with Air Injection since its a 96 y8 head
And with the head and ECU I understand I'd be wiring the 3wire IACV, VTEC, and knock sensor correct?
I do know if I run a P28 it will rid the knock sensor but I want to stay OBD2...
Looking for confirmation on ECU firstly... and wanting to rid of all check engine lights ok first start up
Last edited by ATLien6; Mar 25, 2012 at 07:54 PM. Reason: title change, put questiin in the title to help responders
Old Mar 25, 2012 | 10:03 PM
Alpha Q's Avatar
Default Re: 96 y8 head / 2000 y7 block, what ECU do i use?
P2P is a OBD-2 VTEC ECU.
This is the one you want to use!!
P28 is a OBD-1 VTEC no Knock and no 3 wire IACV
Old Mar 26, 2012 | 04:55 AM
ATLien6's Avatar
Icon2 Re: 96 y8 head / 2000 y7 block, what ECU do i use?
So am I looking for a 96-98 P2P or a 99-00 P2P since my harness is 2000? Also, timing belt and headgasket, y7 timing belt ok and y8 head gasket?
I'm going to replace my head studs also with ARPs
Lastly, where is a good place to pick up pinning/depinning pieces to pin in the knock sensor, Vtec and IACV
Thanks ahead of time
Old Mar 26, 2012 | 04:58 AM
grumblemarc's Avatar
The Grumpiest
96-98 OBD2a
99-00 OBD2b
Old Mar 26, 2012 | 06:36 AM
HondaPartsHero's Avatar
Technical Hero
Wait are you staying automatic? You'll need an auto P2P from a 99-00 EX. Also you'll need to swap the throttle body off your Y7 onto the y8s. You'll have to keep using a 3 wire IACV if you stay auto an you can't use a manual P2P. Also are you keeping the Y7 exhaust manifold? If you want to use the Y8 you has to have a cat welded in and extend your secondary 02 to the new cat location.
Old Mar 26, 2012 | 07:47 AM
ATLien6's Avatar
Yes I'm staying auto , confirmed I'll need an Auto P2P OBD2B ECU and yes ill be using the y7 exhaust manifold until I can track down a y8 manifold here locally or later order a DC 4-1...
Final question, anyone know any good places to track down pinning pieces to pin in the knock sensor, Vtec, and 3wire IACV
Old Mar 26, 2012 | 09:19 AM
Arthas's Avatar
Use a really thin needle to depin, move the wires around and wire up the knock sensor, VTEC and 3 wire IACV.
Your car already has a 3 wire IACV btw. 96-00 AUTOMATIC Ex's called for 3 wires as well.
Old Mar 26, 2012 | 11:15 AM
ATLien6's Avatar
So I'd only be wiring up vtec and knock sensor, won't need to do do the 3wire IACV converspn because above states I already have one correct?
Old Mar 26, 2012 | 01:32 PM
Technical Hero
Yes
Old Mar 26, 2012 | 03:50 PM
ATLien6's Avatar
@hondapartshero
Thanks for all your help, good answers and straight to the point, and no noob this n that... very appreciated
Old Mar 26, 2012 | 03:55 PM
98EJ7Y8's Avatar
i have a 98 civic obd2a p2p ecu for a 5speed civic if you need ??
Old Mar 26, 2012 | 08:18 PM
ATLien6's Avatar
I'm Auto, my sedan is my daily daddy fuel sipper, I've got a built y7 turbo motor that's waiting for a shell for some track fun
Old Mar 26, 2012 | 08:21 PM
jbpnoman's Avatar
Go to your local Sears and pick up some picks and hooks. I bought a set of 4 for like, $20, just to do some repinning, and they've come in handy a lot. Well worth the money, and something everyone should have in their toolbox.
Old Mar 27, 2012 | 01:05 AM
Technical Hero
Yeah on thy last pic you don't have to use a pin or hook. After you click up all the tabs the pin pulls right out without much effort. For OBD1 pins it's a different story.
Old Apr 5, 2012 | 07:47 AM
vince819's Avatar
hey i have al itle question i have a 98 civic dx manuel trans and ima do the same thing y8 head and intake into my y7.and ima keep my thortle body since the intake i bought didn had 1 and do i need to rewire for iacv?
Chris0619
Dec 1, 2013 04:15 PM
pwnsauce ek
Nov 14, 2012 01:28 AM
JDM-KIDD
Oct 1, 2010 01:32 AM
EJ8 944
10
Jan 27, 2007 03:51 PM
Eaglekper0046
Dec 17, 2005 09:57 AM
