96 y8 head / 2000 y7 block, what ECU do i use?
Before everyone tells me to search search this has been answered 100 times blah blah; take the time to understand that I'm new to the forum, just like you were once, and haven't quite got the hang of searching specifically and finding specifically the answers I'm looking for ... so with that said, I'll cut to the chase....
My car- 2000 Civic LX, Auto Tranny, Stock motor (hush! its my daily daddy father husband car)
I have a y8 head and intake manifold off a 1996 EX, both complete
Question - I know they will mate and work, my question lies in what ECU would I run, 96-98 or 99-00 P2P
Won't have to bother with Air Injection since its a 96 y8 head
And with the head and ECU I understand I'd be wiring the 3wire IACV, VTEC, and knock sensor correct?
I do know if I run a P28 it will rid the knock sensor but I want to stay OBD2...
Looking for confirmation on ECU firstly... and wanting to rid of all check engine lights ok first start up
Last edited by ATLien6; 03-25-2012 at 07:54 PM. Reason: title change, put questiin in the title to help responders
Re: 96 y8 head / 2000 y7 block, what ECU do i use?
I'm going to replace my head studs also with ARPs
Lastly, where is a good place to pick up pinning/depinning pieces to pin in the knock sensor, Vtec and IACV
Thanks ahead of time
Technical Hero
Wait are you staying automatic? You'll need an auto P2P from a 99-00 EX. Also you'll need to swap the throttle body off your Y7 onto the y8s. You'll have to keep using a 3 wire IACV if you stay auto an you can't use a manual P2P. Also are you keeping the Y7 exhaust manifold? If you want to use the Y8 you has to have a cat welded in and extend your secondary 02 to the new cat location.
Final question, anyone know any good places to track down pinning pieces to pin in the knock sensor, Vtec, and 3wire IACV
Use a really thin needle to depin, move the wires around and wire up the knock sensor, VTEC and 3 wire IACV.
Your car already has a 3 wire IACV btw. 96-00 AUTOMATIC Ex's called for 3 wires as well.
So I'd only be wiring up vtec and knock sensor, won't need to do do the 3wire IACV converspn because above states I already have one correct?
@hondapartshero
Thanks for all your help, good answers and straight to the point, and no noob this n that... very appreciated
Go to your local Sears and pick up some picks and hooks. I bought a set of 4 for like, $20, just to do some repinning, and they've come in handy a lot. Well worth the money, and something everyone should have in their toolbox.
Technical Hero
Yeah on thy last pic you don't have to use a pin or hook. After you click up all the tabs the pin pulls right out without much effort. For OBD1 pins it's a different story.
hey i have al itle question i have a 98 civic dx manuel trans and ima do the same thing y8 head and intake into my y7.and ima keep my thortle body since the intake i bought didn had 1 and do i need to rewire for iacv?
pwnsauce ek
11-14-2012 01:28 AM
JDM-KIDD
10-01-2010 01:32 AM
EJ8 944
10
01-27-2007 03:51 PM
