Brake Pedal Goes Straight to the Floor
Old Mar 25, 2012 | 07:23 PM
da1lydr1ver's Avatar
Default Brake Pedal Goes Straight to the Floor
Hi everyone.
I took my car out of winter storage today after not driving it for about 5 months. When I rolled down the driveway, I hit the brakes and the pedal went straught to the floor with pretty much no pressure. I had to use the ebrake to stop the car. When I pump the brakes the engine does rev up. The brake fluid resivoir was lower than the MIN marking.
The car worked perfectly before storage. I think it may be related to the brake master cylinder. Maybe the seal in that went out? there is no brake fluid on the ground or on any of the calipers front and back.
Any suggestions on what it can be? The car is a 1992 civic hatchback.
Thanks
Old Mar 25, 2012 | 11:07 PM
jbpnoman's Avatar
Default Re: Brake Pedal Goes Straight to the Floor
Start off by getting yourself a bottle of Honda brake fluid, and giving the system a full bleed.
Old Mar 25, 2012 | 11:16 PM
Alpha Q's Avatar
X2 air may be in the line...
Old Mar 26, 2012 | 01:22 AM
Thomas 918's Avatar
I had this problem and it ended up being the brake booster.
Old Mar 26, 2012 | 02:13 AM
HowsTheHonda's Avatar
I currently have this problem on my 89 civic, It's the brake booster in my situation & it's hard to find a brake booster for this year, found it though so i guess i just need to order it.
brake booster, brake drum.
best of luck
Old Mar 26, 2012 | 01:50 PM
isnt it odd if the lines all of a sudden got air in them? granted, the car has been sitting around for 5 months, but the brake resivoir still had fluid in it.
its a cheap enough fix, maybe i'll try this first.
Old Mar 26, 2012 | 06:25 PM
jbpnoman's Avatar
It's not that the lines got air in them, its that the fluid deteriorated from not being used. It happened to my 98 during the 6 months it spent on jack stands, and a quick bleed fixed it right up.
hteg12
Jul 18, 2013 05:13 PM
da1lydr1ver
Suspension & Brakes
Mar 28, 2012 06:56 PM
UltimX
21
Feb 8, 2006 08:29 PM
H.crx-si
Jul 6, 2003 10:05 AM
dnt94civic
Jun 7, 2002 05:04 AM
