90.5mm k24 potential???
Old Mar 25, 2012 | 06:42 PM
Mach1n1st's Avatar
Default 90.5mm k24 potential???
90.5mm worth it or is it to much risk?
Old Mar 25, 2012 | 07:46 PM
doood's Avatar
been there done that
Default Re: 90.5mm k24 potential???
for anything other than a race only motor you're pushing it
Old Apr 10, 2012 | 06:55 AM
CHEETAH's Avatar
only if 90 bore already and sleeves have scars so you need to bore 0.5mm then it might be worth it...for discplacement, you'll barely see anything.
Old Apr 23, 2012 | 09:03 PM
Twenty47's Avatar
word on the street is the headgasket doesnt last.
Old Jun 22, 2012 | 09:18 AM
Darton's Avatar
The bore center of a K24 block is 94mm. If you try and go to a 90.5mm bore that will only leave .069 of wall per side to try and seal the head gasket. The gasket will not last long and you dont gain anything by going .5mm larger than 90mm.
roycivic92
Apr 7, 2010 10:07 AM
92HB_HB
Sep 12, 2005 09:28 PM
Turbocivic94
Apr 25, 2005 06:21 PM
forcedaccord95
Jan 29, 2003 07:29 AM
schwett
Jun 18, 2002 06:22 AM
