d16z6Tcrx 700whp stock sleeve daily driven street car!!!! CMR tuned
just got off the dyno last night with Chis Miller. very happy with the results.
super simple setup.
jdm gsr stock sleeves
ls crank
eagle rods
supertech 10.5:1 pistons
supertech springs and retainers
type r cams
bosch 1600cc injectors
walbro 400lph
jdl divided bottom mount manifold
pte 6766 .82 t3
gsr trans
obx lsd
ebay xtd stage 5 clutch
stock axles
693whp 417ftlbs @ 27.5psi
i could be more pleased. Miller said he had it really fat on the 693 pass and that once he leaned it out it would have put up a 7XX on the screen but i told him theres no need. he leaned it out in the map but we didnt run it again. he said its making great power and has alot of room for more. there was only 14 degrees of timing on that last pull. at the track we can add it in and turn it up to 32 psi if it will hold it. he was very proud to be a part of this build and was excited to see it come together. as a customer and a friend those are things this industry needs more of.
here is the full build thread.
https://honda-tech.com/forums/forced-induction-16/d16z6tcrxs-9-sec-stock-sleeve-daily-driven-build-thread-3005702/
super simple setup.
ls crank
eagle rods
type r cams
walbro 400lph
pte 6766 .82 t3
gsr trans
obx lsd
stock axles
OP, you thread title is a little misleading. Lol.
But, I like what you've done. I just read your other thread. Props
extremely seriouse when its also in the title of the thread this is why it was pointed out to you
did you also get the attitude when you was tuning or what man
What up man. followed your build thread..simple and a beast of a setup. I see single digits in your future. It gives me hope because my build is on stock sleeves..was waiting to hear what numbers you were goin be pullin and all i gotta say is im smiling ear to ear..ill pm u once i get my numbers
It is on q16.
thank man
