A fresh look at race switch panels
Old Mar 24, 2012 | 02:37 PM
Leonides's Avatar
Default A fresh look at race switch panels
Recently made a race switch panel for a customer and just wanted to show you guys. It doesn't come cheap since switches are rated to last.
Green Button is the Pushbutton Start Switch.
Red with arrows turns all engine functions. (Fuel Pump, ECU, Coil, Injectors etc.)
The four black Switches can be configured to turn on whatever you like. In my customers case, it's an override function Electric waterpump, Fuel pump, Radiator fan and ECU.
Old Mar 24, 2012 | 02:41 PM
Leonides's Avatar
Default Re: A fresh look at race switch panels
A more common switch used in most of the race cars. Environmentally sealed agains dust, oil and other crap.
Red turns on all engine functions.
2nd button is a momentary rocker switch for starting the engine.
4 switches on the left can be configured to turn on any device you like.
Old Mar 24, 2012 | 02:45 PM
Leonides's Avatar
Fabbing up a panel to hold the Boost Controller and Turbo timer.
Old Mar 24, 2012 | 07:59 PM
adrian1281's Avatar
Looks nice, if you don't mind me asking where did you source the leds from? Do they come with that white/silver bezel around the edge?
Originally Posted by Leonides
Old Mar 25, 2012 | 12:34 AM
Leonides's Avatar
Bought the pilot lights locally. Most lights I have seen are like $9-15 each. This one is way cheaper and rated to have 25000 hoirs lifespan.
I said pilot light since this uses a standard 12v bulb. I have seen some with silver trim. That one has a white trim/bezel.
Old Mar 25, 2012 | 08:53 AM
known's Avatar
Really nice panel.
How did you cut and shape the fiber pieces?
Old Mar 25, 2012 | 10:52 AM
Leonides's Avatar
I used an artist knife to cut the carbon. It is a 3m Dinoc vinyl sticker.
When I did a real carbon fiber on I remember using a dremel cut off tool. but it took a lot of time. Sand Paper to finish.
Old Mar 26, 2012 | 04:17 AM
2point2's Avatar
Not enough switch panel threads! Nice work.
lexan works great too and is much easier to cut/drill etc.
Old Mar 26, 2012 | 07:36 AM
Chugger's Avatar
very nice panels i was thinking about making myself one and incorporating a usb for easy labtop hookup to ecu for tuning and what not
Old Mar 26, 2012 | 11:10 AM
CRMB's Avatar
OG Fabricator
Love the e-stop.
Old Mar 28, 2012 | 08:35 AM
Leonides's Avatar
Yes lexan is great too. If we make more of these then we will use waterjet to cut.
Old Mar 28, 2012 | 08:39 AM
Leonides's Avatar
Mine goes in the relay/fuse/ecu panel. Not needed. Really but I wanna save the ECU USB from being abused.
Old Mar 28, 2012 | 10:35 AM
Snow Trooper's Avatar
OG Fabricator
Good work, switches are nice, that e-stop is really cool.
I work with composites a lot and I was fooled in the first pics, then I almost was like WTF when I saw the metal plate, then I was almost annoyed for a split second yet it quickly turned to me thin king its cool and I will probably do something similar for the right car.
I have used Di-noc and it is really cool material, never though of using it this way to make a easy panel.
integra_101
Jul 29, 2014 07:25 AM
Mr.Death
Audio / Security / Video
Jul 21, 2008 07:11 PM
DC4_MADMAN
Jan 11, 2008 09:33 AM
alacard
11
Jan 12, 2007 07:27 PM
my_slow_civic
12
May 9, 2005 07:08 PM
