swapping pistons even worth it?
Old Mar 24, 2012 | 10:41 AM
teggy!'s Avatar
Default swapping pistons even worth it?
what up guys. i have a gsr with roughly 60k on it that i picked up off a buddy. its bone stock and im looking to use it as a replacement for the deathly ill LS thats in my integra atm. the head is already off so i was thinking that i want to bump up the compression a little, plus new rings never hurt. just wondering should i shell out the money for a set of p73-00 pistons and is it a really noticeable difference from the gsrs 10.1 comp?
moneys a little tight right now and i would rather not throw it at my motor for something i wont even notice.
Old Mar 24, 2012 | 10:47 AM
Dc4LsTeG's Avatar
EK9
Default Re: swapping pistons even worth it?
Get the p73s
Old Mar 24, 2012 | 11:01 AM
doood's Avatar
been there done that
it's not as simple as just swapping pistons. **** starts adding up quick.
Old Mar 24, 2012 | 11:13 AM
tegman97's Avatar
I think it'd cost way more than it's worth. I know the pistons you're talking about are the 11.1 compression, but I ended up having to replace my b18c1 with a jdm b18c; which has pistons with a 10.6:1 compression ratio. Supposedly that results in 190hp over the usdm which has 180. I couldn't tell any difference.
Idk what those pistons would go for, but wouldn't you have to have your block honed when you replaced them? And labor for tearing it all down and putting it back together would be expensive, unless you're doing it yourself.
I don't think 20hp is worth that much money
Old Mar 24, 2012 | 11:14 AM
B20ztek's Avatar
I wouldnt if moneys tight. Don't want to start something you may not be able to finish.
Old Mar 24, 2012 | 11:15 AM
Dc4LsTeG's Avatar
EK9
OP your rebuilding it either way correct? Your just asking if you should buy the p72s or p73s right?
Old Mar 24, 2012 | 11:22 AM
JuggerNaut-CTR's Avatar
p73-00 pistons = 11.59:1 compression using a oem 3-layer h/g on a b18c1.
You'll notice little difference with the compression bump. Headwork w/ that compression is where its @.
Old Mar 24, 2012 | 11:26 AM
tegman97's Avatar
I thought the p73-00 were 11.1:1?
http://www.ff-squad.com/tech/temp/pistons.htm
Old Mar 24, 2012 | 11:33 AM
Depends what motor they are in. In a itr those pistons net 11.1:1.
Use this compression calculator and plug in b18c/1 into all the slots, but select p73-00 for the piston slot.
http://www.zealautowerks.com/bseries.html
Old Mar 24, 2012 | 11:41 AM
tegman97's Avatar
Oh, I see. That's a bigger compression jump than I thought then. I still don't think it'd be worth the money though, unless op is doing a whole rebuild but what I got out of it was he just wanted to do pistons and rings
Old Mar 25, 2012 | 05:29 AM
teggy!'s Avatar
I wanted to just swap the pistons. Rings were on my list before I throw it in as well. I'm looking to get some gains where I can but reliability is my main concern. I can get them for around 200 bucks, plus the rings. Im planning on staying na
Old Mar 25, 2012 | 12:13 PM
doood's Avatar
you cant expect to just throw new pistons in without a tune or anything else and get gains
haroldthefly91crx
Jun 7, 2007 07:42 AM
Bspec18
Oct 4, 2005 03:11 PM
BLK99VTECR
Jan 19, 2005 06:40 PM
808b18c1boosted
Apr 23, 2004 12:30 PM
jetdriven
May 6, 2002 06:44 AM
