I need help/tips on SRS light & horn after quick release setup install.
Okay so I did a few research and I here's what I plan to get for the setup. A NRG short hub, a NRG quick release, and a NRG hub lock. Steering wheel I'll choose one at my liking. So here's the thing, I have cruise control on my steering wheel, How to I pop that out so I can take off the screws for the airbag? I also I don't want to take the bulb out of the SRS light so I want to do the resistor method. I read some of the posts, but I haven't seen any pictures (pictures are dead links). Based on the information I gathered, I believe I need to get ONE 2.0 OHM resistor and bend it and plug each end to jump pins 1 & 3? And I hear the horn is pin 6, is that true? What do I need to get the horn working? Here Is what I am picturing when I'm reading these tutorials. Does anyone have any pictures of a completed connection with the resistors? THIS IS FOR A 92-95 CIVIC
There isn't a srs bulb. What I did on my setup was just unplugged the connector in the back of the cluster. As for the horn, find which wire is the power wire for the horn and wire it to a paper clip or something else that is flexible that conducts electricity. Wrap the horn wire around your "paper clip" and screw the clip into the plastic trim on the steering column. Make sure your paper clip is touching the back of the short hub at all times. The just connect the wires together that are supplied by NRG through the short hub and quick release. If you get lost pm or something and I'll get some pictures of my setup when I can.
I just bought some resistors, but there were two 2.2 OHMS that I found so I purchased both to save trips. Am I suppose to use the 1/2 watt or 2 watt?
1/2W or 2W
will make no diffrence to what your doing
its all about the Resistance
it would only make a diffrence in a circuit that has higher current dependancy
srs and horn are not that high current dependant
eJone powereD
16
May 23, 2010 08:57 PM
SLEEPER775
Oct 10, 2007 02:45 PM
