suspension help needed!!
Old Mar 23, 2012 | 02:21 PM
Jhicks's Avatar
Default suspension help needed!!
1991 civic hatch si. the car has had a terrible lean on the back driverside since i got the vehicle. ive swapped shocks and spring to try and fix it, but nothing. its still the same. any help? top is rear pass and bottom is rear driverside.
Old Mar 23, 2012 | 02:27 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: suspension help needed!!
Have you actually checked anything like: bushings, strut mount/apron, bent parts, ect?
Old Mar 23, 2012 | 02:48 PM
Jhicks's Avatar
Yeah. I've also been all up under it with a tape measure trying to figure out why it's doing it. I'm thinkin it a bishing and I just can't actually see it.
Old Mar 25, 2012 | 09:19 AM
Jhicks's Avatar
Anyone? Bc I can't figure it out? This ever happen to someone else or what?
Old Mar 25, 2012 | 03:24 PM
GRIM516's Avatar
try some coilovers and see if u can fix the lean if not then something is bent..
Old Mar 25, 2012 | 04:32 PM
DCRB's Avatar
body isn't twisted is it?
Old Mar 25, 2012 | 05:14 PM
EFnCRX's Avatar
rta bushing completely torn out on one side?
or could you possibly have a trailing arm from a differnt chassis on one side just some ideas..
Old Mar 25, 2012 | 06:13 PM
GRIM516's Avatar
any luck? my experience is spring sag on one side if all else is intact ...
Old Mar 25, 2012 | 11:52 PM
Tyson's Avatar
check for eccentric/worn out bushings and bent suspension arms.
Old Mar 26, 2012 | 05:05 AM
Jhicks's Avatar
The springs and shocks are fine I can't visibly see any worn out bushings or anything bent and I dot believe the chassis is bent. Someone told me to check if there is a bushing between the shock and the body. I haven't had the time to crawl under it. I'll be checking today.
Old Mar 26, 2012 | 05:09 AM
Jhicks's Avatar
And from what I can tell its never been in any kind of accident.
Old Mar 26, 2012 | 08:14 AM
Jhicks's Avatar
are the bushings for the trailing arms and lower control arms press in press out? like with a shop press? bc ill change all the bushings and go from there.
Old Mar 26, 2012 | 08:19 AM
91 EF DX's Avatar
http://www.youtube.com/watch?v=hPTDzrxqoOo
Old Mar 26, 2012 | 08:37 AM
Jhicks's Avatar
what about the lower control arm bushings?
Old Mar 26, 2012 | 08:44 AM
Jhicks's Avatar
i know how to press them out and in. i just want to make sure i dont bust them bc they arent supposed to be pressed out.
Old Apr 2, 2012 | 08:40 AM
Jhicks's Avatar
any specific way to check the bushings? bc i was told they could all be a little worn out and add up the that bad of a lean.
wuggiewuggie
Suspension & Brakes
Feb 22, 2007 11:50 AM
stockcivic103
Aug 18, 2006 09:38 PM
JDuronM
Apr 8, 2005 05:17 AM
jerbear!
Suspension & Brakes
Feb 9, 2005 04:10 AM
.(Lazarus).
Jan 25, 2003 12:32 PM
