Can you put larger tires on back
Old Mar 23, 2012 | 11:01 AM
splashy's Avatar
Default Can you put larger tires on back
Okay, so I have a 1995 del sol s model,
I needed a new back tire so I was able to get 2 good tires off a 1993 del sol si. I didn't realize they were a little bigger until I got home I guess they are 14 inch aluminum rims, so my question is would it be okay to have bigger tires on the back and smaller on the front. I think its 175/70/13 on front, and 185/60/14 I want to put on the back. Hopefully some one here knows about this I have no idea if it's okay or not.
Old Mar 23, 2012 | 11:09 AM
kyden's Avatar
Default Re: Can you put larger tires on back
the tires will actually be the same height.
Old Mar 23, 2012 | 11:52 AM
NACvicSi's Avatar
See attached for difference
Old Mar 23, 2012 | 12:55 PM
splashy's Avatar
Can you elaborate on that, I mean I rolled the tire up to the other one, it's clearly a bit bigger. So you think it is fine to have bigger tires on the back and it wont hurt anything?
Old Mar 23, 2012 | 01:36 PM
lobby350's Avatar
It should be fine. You don't have ABS right?
Old Mar 23, 2012 | 07:18 PM
splashy's Avatar
I don't think, what is it & how do I know if it is there?
Old Mar 23, 2012 | 07:27 PM
grumblemarc's Avatar
The Grumpiest
If you don't know you probably don't have it and it makes absolutely no difference regarding the height of your tires. Refer to the chart in post #3.
Old Mar 23, 2012 | 07:29 PM
JDM_teh_WIN!!'s Avatar
It means the overall diameter of the 14in wheel and tire is 2mm bigger than the 13in wheel and tire. Will it look stupid? Yes. Will it affect anything? No.
It means the rear wheels will rotate slower than the fronts. By how much? I really don't know.
Old Mar 23, 2012 | 07:33 PM
The Grumpiest
I would assume that if the difference is 0.448% it probably rotates 0.448% slower.
Old Mar 23, 2012 | 07:36 PM
Missed that. So now we know. Reading 0wnz!
xPRIMO
Mar 7, 2012 11:05 AM
Chief Nitsuga
Nov 1, 2008 04:07 PM
VTECdohcter
Aug 16, 2007 11:42 AM
povs9
Jul 24, 2007 01:42 AM
DelSolMarine
Jul 7, 2006 06:09 PM
