HELP! 99 GSR swap in 98 EK chassis with stock harness.
Old Mar 22, 2012 | 12:38 PM
JENNY_EG6's Avatar
Default HELP! 99 GSR swap in 98 EK chassis with stock harness.
Hi guys I had a 99 GSR swap in a 98 EK civic, I used the stock harness and did some mods for the IACV, knock sensor, and Crank Position. Last one I ran to was the Intake Air temp sensor. The stock D16Y7 sensor was located on the INTAKE airbox itself, while the GSRs are on the intake manifold. Going to bar soon I was wondering if anyone could help and give some tips on what I should do. COuld i just cut the old single cam plug and use the GSR one to use the Air Temp sensor instead of the one on the intake? Thanks!!!!!!!
Old Mar 22, 2012 | 01:28 PM
JDM_teh_WIN!!'s Avatar
Default Re: HELP! 99 GSR swap in 98 EK chassis with stock harness.
Yeah, if it doesn't reach and it's the same type of connector then just extend the wires.
Old Mar 22, 2012 | 01:32 PM
JENNY_EG6's Avatar
The 2 plugs are different, I'm using the Air Temp Sensor from the GSR. But The plug on my harness was for the Intake Air Temp Sensor. I'm wondering if I should take the plug from the GSR harness and wire it into my stock Ek harness was my question so it would plug.
Also, from what I've heard when you BAR you have to have the Intake Air Temp in as well :/
Old Mar 22, 2012 | 01:35 PM
Yeah, that should work. Are there the same number of wires on each plug?
Old Mar 22, 2012 | 03:54 PM
canadaek's Avatar
they are both intake air temp sensors there just in different places . so yes use the plug off the gsr harness and wire it to your y7 harness and use the gsr sensor .
Old Mar 22, 2012 | 03:56 PM
JENNY_EG6's Avatar
THanks for the feedback guys I'll try this when I get back
Old Mar 22, 2012 | 04:00 PM
canadaek's Avatar
good luck !
Old Mar 22, 2012 | 04:16 PM
nealnanoHX's Avatar
Pretty sure the D series has a different plug on the harness for AIT sensor. You can just use the one off the GSR harness, wire it in (2 wires both plugs will have the same color wires) and call it a day. My 98 Hx had a different AIT plug than the B series, B series is round and D is more square. I just used the D series sensor since it was in the CAI tube so it was easier for my swap.
Old Mar 25, 2012 | 09:50 AM
JENNY_EG6's Avatar
Everything plugged up.. turned to 2nd click no fuel tried cranking.. nothing.... :/ I also notice that there was no "CEL, and Maint" light when I turned the key over.. wondering if some fuses went bad.. anyone?
Old Mar 25, 2012 | 09:57 AM
canadaek's Avatar
check your grounds and fuses (t-stat housing,tranny,valve cover to fender
Old Mar 25, 2012 | 01:15 PM
JENNY_EG6's Avatar
thanks it WAS the ground from the tranny!! started for a bit i heard vacumme leak probably from throttlebody gasket, and then car died. Seems like im gettin fuel now but no sparks ( these are new plugs)
Old Mar 25, 2012 | 03:30 PM
canadaek's Avatar
is the t-stat ground clean and tight ? check the dizzy wiring and the cap and rotor
Old Apr 7, 2012 | 09:17 PM
JENNY_EG6's Avatar
everything runs good now just have a CEL for Knock Sensor, I've replaced the sensor and still same thing
Old Apr 9, 2012 | 05:50 AM
Show15's Avatar
Check continuity between the pin on the ecu plug and the knock sensor plug. When I swapped mine I mixed my IABs and knock sensor wire up in the harness and had a similar issue.
sd619jef9
Jul 5, 2012 11:47 AM
enot767
14
Jan 5, 2011 07:27 PM
marcj
Sep 24, 2008 08:38 AM
sexyazz_ek
Jun 9, 2007 12:20 AM
5genhatch
Sep 18, 2004 09:35 PM
