AC doesn't blow (96 ek)
Well if it has freon in it that would be a problem as the system is r134a . If it's not blowing anything you probably need a blower motor or resistor . Then you can try jumping the a/c clutch relay to see if the compressor spins (the inside part of the pulley the out side always turns)or take in and have it inspected by a professional .
