2004 Accord ac problems - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 04-10-2013, 11:08 AM   #1
Default 2004 Accord ac problems
Car will blow hot air but no cold?
Bear7285 is offline   Reply With Quote
Old 04-10-2013, 11:24 AM   #2
My Name is Nobody
MSchu's Avatar
Default Re: 2004 Accord ac problems
have you had any service done mate?
they need to check for leaks and charge.
MSchu is offline   Reply With Quote
Old 04-10-2013, 03:24 PM   #3
Have not I will have them check it:
Old 04-10-2013, 05:24 PM   #4
The the ac on pop the hood and see if both fans are running. If not it probably has a leak or such. If they are then it could be electrical. Check ac relay by tapping it and see if compressor kicks on
Racer02gtstang is offline   Reply With Quote
Old 04-11-2013, 08:02 AM   #5
thank you I will try that
Old 04-17-2013, 10:39 AM   #6
Ended up being a bad a/c compressor 900 later
Old 05-18-2013, 05:03 PM   #7
Quote:
Sorry to hear that. Where did you take it to? If you had never checked the freon level since you got the car, it could be the problem. The AC system works mostly in the summer and hardly working in the winter time except when you ran the windshield defroster. It usually leak freon in the winter because of dry seals or connectors. You need to run the AC at least once a month when the weather is warm enough to keep it lubricated. When the freon level is low, it will cycle the compressor on and off constantly and is likely the cause of the compressor seized and died. Same go for your home AC too so check that freon level once a year. However, I had similar problem on my older Accord and it turned out to be the relay to control the compressor that failed. It was $180 to get it replaced, a lot better than $900 compressor.
Accordman1 is offline   Reply With Quote
------------------------ thaijdmpart For Sale 0 11-19-2014 11:37 PM
mechanic needed dohcredsol Southern California (Sales) 1 08-29-2013 08:17 PM
Edelbrock victorX Evoinboost For Sale 14 08-29-2013 03:17 PM
. allJDMcivic Honda Civic / Del Sol (1992 - 2000) 9 12-16-2010 04:03 PM
. gotstableo Honda S2000 0 06-03-2007 03:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
