Toyota 2AZFE AEM Issues
Old Mar 21, 2012 | 05:38 PM
Aesthetic Gains's Avatar
Dos Pupusas
Default Toyota 2AZFE AEM Issues
I'm currently in the middle of trying to start this toyota engine. The engine is in a '07 Scion TC.
The car is running AEM 6050 Series 2 box. I can see that the car has the timing settings all screwed up. The box was supposed to come with a basemap, well, it didn't. What I'm basically trying to do is, get the car running and take it to the tuner. I just want to see it start so that I can troubleshoot any mechanical issues, if any.
The engine rpm go from 0rpm to 600rpm and constantly gets timing and sync errors.
What I know so far:
-The crankshaft has 36 minus 2 teeth
-The cam has 3 teeth for the cam sensor
-Has coil on plug set-up from the factory
Where do I input this information?
I'm hoping that the tuning gurus can help on this one. I would be forever in your debt lol
Thanks in advance.
Old Mar 21, 2012 | 06:29 PM
recliner15's Avatar
Default Re: Toyota 2AZFE AEM Issues
Here are a couple screenshots of the settings we have in
Old Mar 22, 2012 | 07:40 AM
xenocron's Avatar
the 30-6050 boxes are for OBD2 hondas which run mag sensors on the distributor.
Are your cam and crank sensors mag as well?
Im pretty sure you would have to go in and change the jumpers (like we do when switching to a T1 cam/crank trigger or AEM EPM) in the AEM to switch that setting, but you would have to call AEM on that...best bet, call AEM and speak to Henry.
Old Mar 22, 2012 | 10:38 AM
Dos Pupusas
I see.
I'll try to get a hold of Henry.
We're hoping to get the car to you next week lol.
Thanks Chris.
Old Mar 22, 2012 | 04:17 PM
Rtype16's Avatar
First question is who sold you the 30-6050? Why did they say it came with a base map for the Scion when it is for a Honda? Who did the wiring in the vehicle or did someone make a jumper harness? Give me some more info and hopefully I can help you out or just call Henry.
Old Mar 22, 2012 | 04:40 PM
recliner15's Avatar
I purchased the 6050 from Dezod Motorsports along with a jumper harness. They informed me the box is "modified" to work with my vehicle.
With the following settings I have the car cranking and reading a steady 220 RPMs
If I change the "Sync Teeth" setting to 0 the car will fire up run for a second with some hiccups then die. It will still show the timing & sync errors.
Of course Stat Sync'd is still OFF.
I have a datalog I can email as well.
I will try to get a hold of Henry tomorrow.
Thanks in advance.
Old Mar 25, 2012 | 10:40 AM
xenocron's Avatar
Sync teeth to 0 will put the car in batch fire mode basically...
Did you get this sorted yet? Did setting the sync teeth to 3 work better?
Old Mar 25, 2012 | 02:35 PM
recliner15's Avatar
Nope havent made any progress. Spent a lot of time on it yesterday.
Got the timing syncd up and spot on as well.
Changing the sync teeth to 3 did not seem to make any difference.
Here are my current settings and my cam/crank wheels.
Old Mar 25, 2012 | 02:38 PM
recliner15's Avatar
Left a message with Henry @ AEM Friday but havent heard back. Will try again tomorrow. REALLY trying to go down the track at Survival Series.
Old Mar 29, 2012 | 09:11 PM
recliner15's Avatar
Track isnt happening this weekend.
Just sent the EMS back to Dezod for inspection and maybe a few changes.
Will see what happens when I get it back next week.
Old Apr 8, 2012 | 06:44 PM
recliner15's Avatar
Sent the ecu back to dezod and the resistors for the cam and crank signal were changed.
Got the ecu back and the car fired right up.
Heading to xenocron Friday morning for a tune.
poweredbysol
Mar 17, 2015 03:40 PM
alperx
Engine Management and Tuning
Dec 4, 2014 10:14 AM
Spoolin18
Aug 12, 2014 08:15 AM
overratedstyles
Nov 20, 2012 03:15 AM
kennymr22
Jan 3, 2005 09:09 PM
