2000 civic si - leaking oil from the head gasket
Old Mar 21, 2012 | 12:34 PM
tgraeter7's Avatar
Default 2000 civic si - leaking oil from the head gasket
Hi i have a 2000 civic si and recently had to do a swap due to a connecting rod busting. i replaced the block with a b16a and replaced the valves, pressure tested and resurfaced the head from the original engine. i put it all together and the damn thing is leaking oil quick fast from the head gasket. do i need a different head gasket with that block? any information will be greatly appreciated. i just want to get my car back on the streets!
Old Mar 21, 2012 | 12:35 PM
Robin6's Avatar
Default Re: 2000 civic si problems
Did you reuse your old head, or is this a new one on your old block?
It should work, but why the leaks? Possible that the head is warped?
was it checked prior to installing?
Old Mar 21, 2012 | 12:47 PM
tgraeter7's Avatar
yes its the original head. it was resurfaced pressure tested andwhat not. the old block is trached with two holes the number four pistons vlaves needed to be replaced because they were bent.
Old Mar 21, 2012 | 01:10 PM
Robin6's Avatar
was the block resurfaced as well as the head?
Old Mar 24, 2012 | 02:28 PM
tgraeter7's Avatar
Default Re: 2000 civic si - leaking oil from the head gasket
no it was not and its purging oil from around cylinder 4. When we turn it over it loses half a quart to a full quart in less than 15 seconds.
Old Mar 24, 2012 | 03:48 PM
zach53's Avatar
pull it apart and stack 2 gaskits c if that works......it will lower your comp but it mite atleast get u back on the road
Old Mar 24, 2012 | 08:59 PM
machetes77's Avatar
the head gasket is up side down...is the oil coming out from the lower back of the distributor?? if yes thats the problem.
Old Mar 24, 2012 | 10:35 PM
blkSi's Avatar
That would maybe be my guess, if the block doesn't have anything wrong with it. Other than the obvious foreign object between the head and block when being installed?
Is oil leaking out of the engine, or internally?
strike1545
May 24, 2010 10:42 AM
thewrai6th
Oct 12, 2009 03:45 PM
pooRmansss
Feb 19, 2009 03:24 PM
C4wrx
Aug 4, 2002 06:23 PM
