questions on B18c1 swap for 94 civix dx sedan
Old Mar 19, 2012 | 06:21 PM
newtoimport2012's Avatar
Icon2 questions on B18c1 swap for 94 civix dx sedan
ok so im in the process of looking for a integra gsr with motor and trans, i know where i can get motor by itself, if i cant get a car with everything under hood, what all do i need to get for the swap, motor has everything on it still, but not sure on the harness part, im sure mines diff being mine is for a non vtech and im going to a vtech, id like to change out to integra dash and cluster but it just depends on if i find car, much help would be appreciated so i know what im in for or a point in the right direction
Old Mar 19, 2012 | 06:32 PM
ehrkeith's Avatar
Default Re: questions on B18c1 swap for 94 civix dx sedan
This has been stated many times just do a search here or google. But simply put
Engine
Transmission
ECU
Wire Harness unplugged at shock towers from GSR, OBD1 preferred
Shift linkage
Axles(Pass, Driver, Mid shaft)
Exhaust etc.
Trans mount from your car
Driver Mount from 94 to 01 integra
Rear mount from 94 to 01 integra
any questions shoot me a pm
Old Mar 19, 2012 | 09:52 PM
Hamarti's Avatar
rywire sells a vtec subharness for swaps like this if you dont have a vtec wiring harness. 55 dollars. Its a simple 3 wire setup. just run it through the firewall to the ECU.
Old Mar 19, 2012 | 10:49 PM
Omegax10's Avatar
I have the rear mount and driver side mount you need if your interested PM ME. Came with my B series swap but I swapped it into an EK and didnt need the mounts.
Slumy__57
Apr 18, 2018 08:25 AM
pimmy98
Feb 4, 2013 12:33 PM
steve_howse2004
29
Dec 21, 2010 07:47 AM
kajay1972
Sep 7, 2007 09:23 PM
NaStYeG
31
Feb 18, 2004 01:17 PM
