B18B1 SWAP HELPP!!!!!!!!!!!!!!
i have a 98 civic si with a 1.6l sohc and would like to swap a b18b1 into it.i have a full 94 integra.i would like to know what i need and what i have to do for this swap..
Re: B18B1 SWAP HELPP!!!!!!!!!!!!!!
In the Hybrid subforum, have you read through these stickies:
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A%2A%2Aokay-lets-cut-down-repeated-qs-about-certain-swaps-post-links-here%2A%2A%2A-650230/
i am trying to get same swap than you, you need t braket driver side complete mount form an 99 SI, axes, linkage, some ecu for that engine and try to plug everyting right on it if you are going to use same wire hardness
forsure an OBD2 to OBD1 harness at least. I don't know if you can wire up an OBD1 wire harness to an OBD2 car though..
i am just going to take the harness out of the integra and put it in the civic.and where and i order cheep parts.
Stancetard Hate Monger
buddy nobody likes answering the same questions 10 thousand times. the answer to your questions has already been posted via hyperlink in this thread...click the search button, and stop cluttering the forum.
no, u cant use the integra harness. just use the civic one. ALSO is the integra manual or automatic? also check out this site:
www.google.com
www.google.com
why cant i just use the harness..and they are boath manual
Last edited by Former User; 12-02-2010 at 08:21 PM. Reason: keep the comments civil
the integra harness is a 2-piece harness and the 96+ civics are one-piece. 92-95 civic and 94-01 integra use the same harness. NOT 96-00 civics. so use the civic one. the integra one will NOT work. use the integra's ECU too. use the integras axles. use the integras shift linkage. use the integra's front seats and rear disc brakes too lol.
well what harness will i use my civic is a 98 and you said i cant use that one.and i dont understand why oi cant use the harness thats in the integra if im putting the integra dash,motor and ecu in
Seagull Management
Not without some modification. The harness wont work unless you use pretty much all of the wiring out of the integra, you'd have to spice the wires going back to the tailights. Its a very involved job, you'll basically have to strip the interiors of both cars down to nothing, dash, steering column, pedals, heater core, etc all have to be removed. Just use the civic harness and modify it, much less work.
The integras harness plugs into another harness, which then goes to the ecu. The civic harness goes from the engine straight to the ecu.
You will need the post mount from a 99-00 Civic Si. If you cant find one, get one from Honda. You will also need the rear T bracket from a 99-00 Civic Si.
From the integra, use the Engine, Trans, axles, shift linkage, halfshaft.
As for the harness, use the one from your civic. You MAY have to leghthen one or two plus and you may have an extra one as well. But I could be wrong about that.
What year is the integra? Due to being in Canada things could be different as well with the wiring...
Hope this helps some.
HAHAHAHAHAHAHAHAHAHAHAHAAAA... this is a funny thread... buddie, this has been covered 10k times.. sorry but true!!....
again try www.google.com
so go ahead and try to perform the swap with the integra harness and get back to me when u have completed it, if u do indeed complete it...
i read something about a jumper harness that just makes the obd2 harness plug into the obd1 ecu..is this a good idea?
