GSR Troubleshooting - Ticking
Old Mar 19, 2012 | 03:30 PM
tylerstephen11's Avatar
Default GSR Troubleshooting - Ticking
I have a B18C1 running on a chipped P28 ecu.
Mods include:
Blox Stage 2 Cams
Titanium Retainers
Dual Valve Springs
Stock Bottom End
It has been making a pretty decently loud ticking sound since I bought the car but at first I thought it was normal. It is fairly loud however.
I changed all my fluids with still the same results.
Tried adjusting valves myself (not sure how precise I was as it was my first go) with no luck also.
Did a compression test and got: 217 220 211 218 (1 through 4)
I'm about ready to send the car to Honda and have them inspect the noise.
My other guesses are that either:
I didn't properly adjust the valves (or adjusted them to wrong spec because of cams)
Worn LMA's
I really hope there is not a greater problem
Any insight?
Thanks
Old Mar 19, 2012 | 04:40 PM
fcm's Avatar
fcm
Old Fart
Default Re: GSR Troubleshooting - Ticking
Spun bearing maybe. 94
Old Mar 19, 2012 | 04:46 PM
DirtyDA9's Avatar
Check valve lash. Remember, valvetrain moves at half the speed of the crank/rotating assembly, so that should somewhat help differentiate top from bottom end tick.
rdeezy78
Apr 4, 2010 10:33 PM
88crxvtec
Sep 29, 2009 11:42 AM
allmotor94teg
Jan 25, 2007 09:35 AM
gsrjay
Aug 23, 2004 01:40 PM
lopey
Feb 26, 2003 08:38 AM
