broke rear lower shock bolt. help
Well my suggestion to you is that you buy new lower control arms. The bushing that the bolt is seized in is junk. I would get a good steel cutting hack saw blade and start cutting the bolt on the other side between the shock and the lower control arm. Then get a vise grips and turn the rest of the bolt out of the nut welded on the shock. That should get your shock loose from the control arm.
Some people will say drill it out. It's not how I would do it but it's another option.
You can replace the bushing it self but it will be a real pain to do.
Drop the LCA/shock in peice. Cut the welded nut off, and try to wiggle the shock off the LCA, or try to pound the bolt out.
OR drop it all, and replace everything. OEM control arms are $67 each from mejestic, but the bushings aren't that hard to replace seperatly.
Which side is it? I have a lca from my 99 coupe. One side was frozen and the other side was fine. I just replaced the entire assembly with aftermarket lcas. Let me know if you're interested!
Yeah, I'm selling a single driver side one for $10 because the same thing happened to me.
Tong.Y
Jun 14, 2010 12:33 AM
Xapt-87
Suspension & Brakes
Oct 6, 2007 01:00 PM
puhlode
Feb 2, 2003 12:24 PM
anyone have any tips/advice on getting it out?
