OL idle is perfect, CL terrible?
Old Mar 19, 2012 | 12:11 PM
MalcolmV8's Avatar
Default OL idle is perfect, CL terrible?
I'm still in the early stages of tuning because it's my first time and I'm learning still but I've noticed this.
When in open loop my car idles like a champ the way I got it setup. Driving, coming to a stop etc. All good.
Closed loop is hit or miss. It idles "ok" sometimes. Most the time the car sounds like it's missing when idling and often it will surge real bad and die, have to keep re-starting and use the gas pedal to feather it. Put it back in open loop and it idles like a champ.
Do long and short term fuel trims in normal cruise and driving affect idle? could that be why?
Old Mar 19, 2012 | 02:06 PM
GhostAccord's Avatar
Default Re: OL idle is perfect, CL terrible?
What software and hardware are you using for tuning?
Some software has open loop and closed loop fuel corrections that can be adjusted.
Old Mar 19, 2012 | 05:16 PM
MalcolmV8's Avatar
Ah sorry, S300.
Old Mar 19, 2012 | 06:02 PM
Open SManager, load your calibration, select Parameters, select the Closed Loop tab and configure your closed loop options. There are also closed loop compensation options in the Fuel compensation tab. You could also look under the idle tab and see if making adjustments to your idle speed vs coolant temperature (moving) table would help.
In the closed loop configuration you can set the short term fuel trim settings.
raverx3m
Engine Management and Tuning
Mar 31, 2015 04:43 PM
93preludes
Apr 9, 2008 04:46 AM
welfarepc
Sep 13, 2007 05:15 PM
Hyaboosta
Jul 13, 2005 02:14 PM
BoostedD15B7
Nov 12, 2003 05:53 PM
