2000 EM1, what block to make more torque?
Old Mar 19, 2012 | 07:10 AM
t0wardseternity's Avatar
Default 2000 EM1, what block to make more torque?
I've got a virgin b16a2 in my 00 si. It's got all the bolt ons (4-1 header, skunk2 catback, intake) and an ITR tranny. I'm trying to decide which block I should start shopping around for that while give me the most midrange torque that will bolt up directly to my a2 head. Trying to keep the cost low and I've heard the b20's go for pretty cheap. With my itr trans I drive between 2.5-4k rpms and would love to boost the torque in that range.
Pros, cons of b18b vs b20? GSR to keep the compression up?
Old Mar 19, 2012 | 07:17 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 2000 EM1, what block to make more torque?
Jeezus Chris do a search! These things have been beaten to DEATH. At least one of these pops up a week!
Old Mar 19, 2012 | 09:50 AM
Da Dust Bunny's Avatar
Mid range torque??? K24. That's going to be your best bet. B series aren't going to put out like the k's will.
Old Mar 19, 2012 | 12:07 PM
I read a couple other topics on the same subject and everybody seems to be split between b20 and b18b. I should have been clearer in asking which B SERIES block would increase my torque, and would also bolt directly up to my a2 head with the LEAST amount of work/extra parts and also be reliable.
Old Mar 19, 2012 | 12:15 PM
The Grumpiest
If you've read you should be able to compare pros and cons yourself. B-series aren't that torquey anyway. Toss that B- and drop in an H.
Old Mar 19, 2012 | 01:28 PM
doood's Avatar
been there done that
Either b20 or b18 will require the same amount of work. The b20 obviously has more displacement.
Old Mar 19, 2012 | 01:30 PM
m_shake's Avatar
bored & stroked k24 son!!
Old Mar 19, 2012 | 01:50 PM
JDM_teh_WIN!!'s Avatar
Why don't you just turbo your B16, you'll have more torque and horsepower than any N/A honda motor.
Old Mar 19, 2012 | 03:02 PM
SimpleTire's Avatar
If I was you I would get a type r block, you already got the transmission it will go well together. With the B20 you have to run a new oil line which basically means you have to do a b20 v tech mod. Which you will have to do more work and put in more money. The type r block will give you more than what you need and it will just bolt on. Hope this helps.
Happy building!
Old Mar 19, 2012 | 03:15 PM
Deetz's Avatar
Crazy Honda Guy
The block is a P72, it is found on B16B, 94+ GSR and 97-01 Type R models. For the $$, the GSR shortblock will give you best bang for the buck out of those choices
Old Mar 19, 2012 | 11:56 PM
go hard jersey's Avatar
but i thought he asked for torque? if its gotta be B series obviously the B20 is going to give you more torque....and as far as the oil.....dude come on its a friggin $100 ordeal that takes about 30 minutes to run so come on. you just buy the eagle or blocks KIT. end of borey.....yawwwnnnn anyway you look at it though your still just going to get spanked on regardless. its not 2005 anymore everybody's fast now. my honest advise to you is keep your existing B16 and turbo it, that will be the most fun, and probably would only cost you 1500 more than doing your b20 thing.
Old Mar 20, 2012 | 12:01 AM
SloHa+ch's Avatar
just boost b16 man.
Old Mar 20, 2012 | 12:09 AM
agreed. b20 vtec isn't going to be all that much better, i don't think you'll be all that impressed, and like i said your still gonna be getting spanked.
Old Mar 20, 2012 | 12:45 PM
kingofbattle909's Avatar
not sher uv quest.
straight 6 lotta torc
raverx3m
16
Aug 30, 2012 07:31 AM
ej1_Bseries
12
May 31, 2011 06:57 PM
cranker
Sep 13, 2010 10:15 PM
square_1
15
Dec 24, 2007 06:47 AM
wanabecivicex
Oct 20, 2002 06:53 PM
