Help! 96 Del Sol Idle Dip!
i have a 96 del sol and when i turn on my head lights the idle dips down around 200 rpms. then when i drive with the head lights on, coming to a stop, "clutch in and shift to nuetral" the rpms dip down to around 300-400 once in awhile. only does this when car is warm/hot. my alternator seems fine and same with the battery. aslo cleaned throttle body and iacv but still no luck. any ideas? also i have MSD ignition coils, caps and wires. the cap zaps me.. any help is appreciated!!
Sometimes wires and not sheilded properly or say old wires will cause electrical issues. When I had my car say 50k miles (fairly new) turned on the wipers or rear defroster my idle would dip, I changed out my wires and the problem went away.
could my msd ignition or bad wires be causing this problem? because when the car is cold, its running fine.. so im assuming it has something to do with being in closed loop? also when i disconnected iacv with car running, idle did not change but instead CEL came on and i got multiple misfires and IACV.
okay so i checked the cap,wires and distributor, the rotor was ****ed. replaced it but still didnt fix my problem, however i discovered when the headlights and fan were on full blast, the alternator voltage drops down to 12.8 and stays there for awhile. could this problem be my charging system? with no electrical load, it would read 14 or 13.9
hmm i did some searches and thought would a dirty map sensor cause this idle dip or a faulty vss??
What worries me the drop in voltage that is a load issue not a MAP issue. You did the test running access, with the lights on and say rear defroster should still stay strong at 14 volts, this with the car running not just key on.
Neverm|nd
11
Jul 21, 2016 05:19 PM
Neverm|nd
Jul 31, 2015 10:03 AM
