No start after taking off the cap
So I removed my cap to inspect it to hopefully figure out why my car was stumbling but I put the cap back on and it wouldn't start. The car is getting fuel and getting spark. The ignitor has a burn spot on it. But if the ignitor was bad I wouldn't have spark. Any suggestions?
http://www.autozone.com/autozone/par...er=509936_0_0_
So I'm pretty sure my plugs are fouled. Would these plugs be accetable? They are one of the 4 different types on ngk's website.
and the tps code was there before? i wouldn't think that tps issues would cause a no start. but try unplugging it and see if it at least fires up
but it sounds more like an issue with your distributor. can you get a hold of a test unit?
Plugs were fouled so I bought new plugs and it still just cranks. Ignition coil was replaced yesterday. I get fuel, spark, air and my timing is good. Any ideas guys? I'm leaning towards just buying a new distributor but I really don't have $200 to blow on one.
Are you saying you now have good spark?
If so, try this, pull all the spark plugs and let the cylinders "dry out", the constant trying to start the engine has most likely "washed" the cylinders and compression will be very low.
Allow the cylinders to air out, then drop in a little oil into each cylinder and turn the engine over a few times, using a bypass jump, [do not turn on the ign.] reinstall the plugs and see if it will fire up. 94
spoonhbk11
11
Jun 9, 2019 07:03 PM
Erik Nielsen
Feb 15, 2017 05:07 PM
the soL that could
15
Aug 27, 2011 06:44 PM
