92 honda civic sohc vtec . replaced cap and rotor now hesitates
Replaced cap and rotor but not wires due to being fairly new . ran perfect before now after change it hesitates when warm at about quarter throttle .
PLEASE HELP !
PLEASE HELP !
Tried replacing plugs and wires and new fuel filter still hesitates almost like it cuts completely out unless giving more throttle.....
Carbon connection ? What's that ..ain't a Honda tech lol
There is very small part inside the middel of the cap that they don't give you when replacing your rotor which is odd. But if you remove the cap and look , it will be there or it won't.
Its like flint to a lighter. there is metal inside the cap so it my not be a full connection with out this part.
Did it run like that before the cap and rotor?
Was it a honda cap and rotor or aftermarket? If so was the rotor a push fit or did it have an opening for a set screw?
The cap before was a clear cap guessing aftermarket and the rotor came out like it was pressure fit but now I replaced just standard cap and rotor and this rotor has spot for set screw but I don't have one
Could this be the problem ? No set screw?
That is possible the screw is cheap, get one and put it in.
mormonboy
May 2, 2007 02:32 PM
kstafford
Sep 6, 2004 02:03 PM
Unjockable
20
Feb 15, 2004 03:49 PM
