did i fry my ignition coil?
Old Mar 15, 2012 | 09:04 PM
4 door beast's Avatar
Default did i fry my ignition coil?
i was doing a compression check and left the wire plugged into the distributor and didnt unplug the distributor and now it wont start? how could i check if the coil is bad?
Old Mar 15, 2012 | 09:14 PM
sebTeggy's Avatar
Default Re: did i fry my ignition coil?
Sounds like you fried the dizzy. If you remove it and open it up, there is a place where you can put a voltmeter to check. Ill look it up and edit
EDIT: I Think spec is 0.6-0.8 ohms
Old Mar 15, 2012 | 09:18 PM
NemesisCBR's Avatar
http://www.team-integra.net/forum/bl...eshooting.html
Old Mar 15, 2012 | 10:01 PM
well im an idiot and i realized the first time i checked the compression i had 3 wires in and connected to plugs while i checked one cylinder at a time, and i didnt even have the throttle open i really think i fried something :\
Old Mar 15, 2012 | 10:08 PM
NemesisCBR's Avatar
Only one way to know! Follow the steps.. or check randomly and end up at the same place or starting at step one anyway.
Old Mar 15, 2012 | 10:21 PM
racebum's Avatar
that coil test isn't always accurate. if you do a compression test and don't unhook the distributor you will fry the coil, not the whole distributor. go to vatozone and buy a $20 cheapie, pop it in and go.
Old Mar 15, 2012 | 11:58 PM
NemesisCBR's Avatar
elaborate please on inaccuracy
Old Mar 16, 2012 | 03:44 AM
TheRealTegger's Avatar
There's only one practical way: Look at it.
See my page on what to look for:
http://www.tegger.com/hondafaq/badse...al-arcing.html
You cannot test the coil with a multimeter. And there is a good chance you've killed your coil.
Old Mar 16, 2012 | 06:11 AM
ive never replaced a ignition coil is it pretty simple?
Old Mar 16, 2012 | 06:49 AM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
Yup. VERY easy. This vid is of a Civic, but same applies to Integras.
http://www.youtube.com/watch?v=37WRlJz84iA
Old Mar 16, 2012 | 03:19 PM
racebum's Avatar
Adj. 1. inaccurate - not exact; "an inaccurate translation"; "the thermometer is inaccurate"
incorrect, wrong - not correct; not in conformity with fact or truth; "an incorrect calculation"; "the report in the paper is wrong"; "your information is wrong"; "the clock showed the wrong time"; "found themselves on the wrong road"; "based on the wrong assumptions"
inexact - not exact
imprecise - not precise; "imprecise astronomical observations"; "the terms he used were imprecise and emotional"
racebum's Avatar
extremely, ranks up there with changing spark plugs
Old Mar 16, 2012 | 03:55 PM
Turboteg27's Avatar
beer batter it befor you fry it next time. very tasty!!!
spoolineh2
Jan 8, 2012 06:50 PM
rollinswapshop
Mar 16, 2011 07:43 PM
rollinswapshop
Mar 15, 2011 03:11 PM
Sinner
Aug 11, 2005 07:59 AM
pootie.teng
May 27, 2005 08:56 PM
