PLEASE HELP ME!! car wont start, spark plug issue
Old Mar 15, 2012 | 07:02 PM
4 door beast's Avatar
Default PLEASE HELP ME!! car wont start, spark plug issue
i was performing a compression check on my car and i went to put the spark plug wires back in and one broke so i went to get a set of those crappy duralast wires and i know theyre making contact, but are there any ways i can check an see maybe my distributor isnt getting juice? it cranks just doesnt start idk im an idiot at this stuff i guess but i really need help!!
Old Mar 15, 2012 | 08:06 PM
DirtyDA9's Avatar
Default Re: PLEASE HELP ME!! car wont start, spark plug issue
How do you know you're not getting spark? Did you actually check to see if the plugs are actuall sparking?
Old Mar 15, 2012 | 08:20 PM
well i plugged a spark plug into a wire and set it on the valve cover cranked it and no spark!
Old Mar 16, 2012 | 05:43 AM
fcm's Avatar
fcm
Old Fart
"Set it" on the valve cover?
You need to make sure the spark plug is grounded, "setting" it on the VC is no guarantee it will ground properly. 94
Old Mar 16, 2012 | 10:45 AM
DirtyDA9's Avatar
^^ agreed. Especially since valve covers are painted lol.
Hold it to a bolt on the rad support.
Old Mar 16, 2012 | 02:51 PM
TheRealTegger's Avatar
Ohhhh, so you were cranking it over with the plug wires removed, right?
If so, then you've put a giant wooden stake right through the heart of your coil.
Old Mar 16, 2012 | 03:20 PM
DirtyDA9's Avatar
^^^ I'm thinking just the spark plug side removed to do the comp test. Not the entire wire removed.
Old Mar 16, 2012 | 03:34 PM
Either way, the HT current had no place to go, so...
http://www.tegger.com/hondafaq/badse...al-arcing.html
You need to unplug the connectors from the distributors before doing the comp test, to prevent power from getting to the coil in the first place.
Old Mar 16, 2012 | 07:55 PM
el crapitan's Avatar
it's not the fact that it's painted. the valve cover doesn't actually make metal to metal contact with the motor because of the seal and grommets. the only thing grounding it to the chassis is the tiny 16 gauge wire.
Old Mar 16, 2012 | 09:37 PM
fcm's Avatar
fcm
Old Fart
It has more to do with the paint, and if all you have is a 16ga wire grounding your VC, fix it.
The "stock" VC ground, [Sub Ground Cable] would easily handel the load of a spark plug, it's the paint, trust me. 94
Old Mar 16, 2012 | 09:48 PM
well then. i retract that statement
and yea, i was thinking about the other little wire that comes off the vc ground. that ones more like an 18 gauge though. but yea, the vc is probably something like a 10 or 12 gauge
Old Mar 18, 2012 | 09:05 PM
91tealb18bef's Avatar
Gotta problem with my start of my car it cranks but doesnt
Turn on I have a 91 ef with a b1 swaplooking to change everything
To obd1 if any could help I would be gratefull
Old Mar 18, 2012 | 09:06 PM
Boosted96gsr
Jan 9, 2012 08:04 PM
slk08
May 20, 2009 11:09 AM
Civic Hybrid
10
Aug 17, 2008 09:35 AM
skata89
May 21, 2006 03:32 PM
