Turbo parts
Hi just want to confirm if there is anything else I need for my turbo setup so far this is what I have got
Garrett turbo with internal actuator
sump with oil return fitted
turbo manifold
down pipe
Blitz sbc boost controller
boost gauge
blitz bov
braided oil feed line
braided water cooled lines
550cc rc injectors
gaskets
aem wide band
p28 socketed ecu
welbro fuel pump
Intercooler kit
K&N filter
1 step colder spark plugs
oil pressure gauge
New ignition leads cap coil fitted
oil, oil filter
fuel filter
remap once everything is fitted. If anyone can please confirm the above is correct or if am missing anything
thanks
turbo manifold
down pipe
boost gauge
blitz bov
550cc rc injectors
gaskets
aem wide band
p28 socketed ecu
welbro fuel pump
Intercooler kit
K&N filter
oil pressure gauge
oil, oil filter
fuel filter
thanks
One step colder plugs, new cap, rotor and wires
New fuel filter
New oil filter and 4qts of full synthetic oil
Vacuum lines for waste gate, BOV and boost controller
Dyno tuning!!!!!
Crank case vent can is a very good idea
A oil pressure gauge is a good idea as well
and lastly some track time, the best part
What motor and sized turbo are you running?? What is your power goal???
New fuel filter
Dyno tuning!!!!!
First post edited looks like i have got everything apart from Crank case vent can. Any idea best way to hook up a catch can? Can you leave the pcv valve disconnected?
Motor is a b18c4 And turbo is a Garrett T3 only aiming for 250/260bhp for the time being.
At the moment its producing 185bhp with the following parts fitted
Tri y header
ek9 type r cams
bmc filter
2.5" b pipe with mugen twinloop backbox
skunk2 inlet manifold
70mm throttle body
thanks
Tri y header
ek9 type r cams
bmc filter
70mm throttle body
thanks
I assume the B18C4 is the same as the USDM and JDM B18C1 in the GSR, good motor to start with. 250-260whp is no problem. Ok I got that it is a Garrett T3 turbo what are the specs on it. The size turbo you use has everything to do with when and how much power you make.
IF you care about DRAG RACING. Very few enthusiasts in the U.K. worry about that kind of stuff. There are also those in the U.S. at higher than 400whp, that don't use it either. Because the world doesn't always revolve around drag racing, where it is used most.
Could not agree more. There is so much more to life then a high peak number. Especially in real world day to day use.
I agree that a real world street Honda does not need more than 350whp even that is stupid fast and cant get the power to the ground.
If you do a crank case vent can correctly you can remove the PCV system all together as it will not be needed. All crank case pressure will vent to atmosphere. I just have a small Ebay oil catch can that I modified into a vent can with a Filter on top and a drain back into the block, I got the H22 block fittings for the vent source on my B18 block and ran oil resistant lines from the block to the vent can.
I think it has a lot to do with marketing and magazines. They have pumped the idea into most people's heads that having a big number is more important than anything else. Throttle response is where it's at, I would hate driving a car that the gas pedal is just basically an off switch.
running 282mm calipers on front and 262mm calipers on rear. Car has tein coilovers fitted 6point roll cage.
Is a vacuum manifold ideal to get?
Also if I didnt wanna run a catch can would it be ok to disconnect the pipe on the pcv valve and leave it hanging?
thanks
thanks
then just vent the VC with a filter or a line going to the air filter tube on your turbo
if you don't want to run a catch can you can buy a 94+ supra twin turbo pcv, they fit in the oem location on a type r and should other black boxes as well. well, at least you could try, worst case you buy the tube for the ITR that comes off the black box. the supra PCV has a positive stop when pressure hits it, no leaking like a oe honda pcv, they also flow more. this puts vacuum on the crankcase when you're out of boost
Would this one be fine
http://www.ebay.co.uk/itm/SC1013-PCV...item58917257e8
Anyone confirm if this setup is fine
Catch can with filter on top and 2 ports
1st port from catch can going to valve cover
2nd port from catch can going to black box on the block where the pcv valve goes?
Also when connecting 2nd port from catch can do I remove the pcv valve from the black box and use a open valve or should i leave the oem pcv valve connected?
thanks for all the help
bart2546
Jan 24, 2007 03:09 AM
