all 4 windows will not roll down
2007 honda accord
90k miles
all 4 windows will not roll down when you press the buttons on the driver side master switch. what can i diagnose to test if i need a new master window switch?
90k miles
i see this master switch fail commonly, But CHAWSKI is correct, fuse continuity with test light/ meter and swapping relays is always better than replacing a $100 switch that isnt the issue. i can give u a master switch test procedure if interetested
i replaced the master window switch and all my windows are working and i can lock the doors from the master window switch. now my keyless entry will not lock, unlock, or open my trunk. i replaced the battery and it still doesnt work. my backup keyless entry doesnt work either
H.N.F
May 17, 2016 10:24 AM
Terabass
Jun 12, 2007 02:29 PM
