B16a - What cams?
^^^Agreed...you could throw some GSR camshafts in there. They are a bit better than the b16's.
If you have the cheese to build the head...turn around and put that into the block. Higher comp pistons (if you're staying all-motor) stronger rods / bearings / etc.
Anymore, you can find a pair of GSR cams for $50. I put a set on a 1999 Si and the guy said it is noticeable, but it's nothing extreme. I didn't get to drive it unfortunately, so I can't attest to exactly how much. Still it's more bang for the buck than most upgrades.
If you have a first Gen B16A don't bother swapping GSR cams in it cause they are the same. B16A SiRII cams are better than B16A 1st Gen or GSR cams. I would go with CTR cams or you could use the Pro1 but you won't get as much power as you would if you had more compression.
If you are on a budget you could look into these.
http://www.crower.com/acura-1-8-gsr-...pair-4388.html
I don't have any first hand knowledge of the power they make but it is a CTR profile.
CANTFAZZDISCHIT
Aug 18, 2003 11:47 AM
