Battery Cut off Switch
Old Mar 14, 2012 | 02:42 PM
91-lsvtecsi's Avatar
Default Battery Cut off Switch
So I have everything wired up minus the wire from the alternator to the battery.. Moroso instruction state i can use 10g wire..How exactly am I running this wire? I have searched and for nothing.. Do I run it from the fuse box or what!? Please help! Thanks!
Old Mar 14, 2012 | 02:45 PM
sanman000719's Avatar
Default Re: Battery Cut off Switch
wire to the battery
Old Mar 14, 2012 | 02:56 PM
And the wire white that is connected to the alternator? Do i eliminate it?
lvdb-2's Avatar
alternator to the + side battery with maby a inline fuse then + side of battery to one terminal on the cut off switch.fuse box power should be coming from the other side of the cut off switch terminal along with starter power..hope that helps
Old Mar 14, 2012 | 02:57 PM
lvdb-2's Avatar
yes it dont need to be pluged in the fuse box any more.
Old Mar 14, 2012 | 03:05 PM
correct doesnt need to be plugged up anymore i just taped mine off after removing it
i am hardwired to the batt from the alt no fuse
Old Mar 14, 2012 | 06:02 PM
Thanks guys! Just to be safe I will be using 4g wire or something along that line!
Old Mar 14, 2012 | 06:11 PM
i used 8 myself
Old Mar 14, 2012 | 08:14 PM
bads2k's Avatar
how did you hook up the other terminal off your cutoff going to starter
Old Mar 14, 2012 | 09:55 PM
theidealone's Avatar
Good topic. I know it comes up every year. But Ive been confused, and needing to wire mine up for years. LOL. I think Im starting to understand...
But just to clarify:
Coming off of the + battery terminal, two wires. One goes to the switch, and the other goes to the alternator.
Coming off of the opposite post on the switch, two wires. One goes to the starter, and the other goes to the fuse box.
Correct?
Old Mar 15, 2012 | 02:36 AM
i ran one wire off the switch to the starter then a seperate wire from starter to fuse box
Old Mar 15, 2012 | 03:39 AM
bads2k's Avatar
Can't you just run the other switch side to the fuse box where the starter wire goes? Instead of to starter then another wire from starter to fuse bo
Old Mar 15, 2012 | 04:36 AM
SPOOLINmatt's Avatar
this topic seems to always get over complicated.
Old Mar 15, 2012 | 04:41 AM
lol and its really simple
Old Mar 15, 2012 | 05:11 AM
MARC P's Avatar
Battery to alt
Battery to 1 side of cutoff
Starter to other side of cutoff
Fuse/switchpanel to same side as starter on cutoff
Not that hard folks
Old Mar 15, 2012 | 06:51 AM
onefstek's Avatar
Just don't run a alternator and it makes it really easy.
Stefan
Old Mar 15, 2012 | 01:34 PM
lvdb-2's Avatar
i just ran a larger wire size from the cut off to the front of the car and tee it off with a little smaller gauge one to the fuse box (my case switch panel) and other directly to the starter. not that hard ..
Old Mar 15, 2012 | 03:28 PM
MARC P's Avatar
Stefan
Thats cheating
Old Mar 15, 2012 | 04:14 PM
hello1320's Avatar
Originally Posted by MARC P
Battery to alt
Not that hard folks
That only works on 76 dodge trucks
notnic3
Jun 12, 2017 11:26 AM
JBLAZE622
Jun 27, 2008 11:55 AM
mrchris1979
Apr 14, 2008 11:55 AM
redboost10
Aug 11, 2006 07:31 PM
hondime9396
Feb 9, 2005 07:01 PM
