iat sensor location
Old Mar 14, 2012 | 06:19 AM
dustinbs144's Avatar
Default iat sensor location
i just put a itr manifold on my b16a2. the itr manifold has the hole for a iat sensor in the runner but my si had the sensor in the intake arm. is one location more accurate or better then the other? it seems the itr iat sensor location would give it hotter readings. anyone have and insight on this?
Old Mar 14, 2012 | 06:39 AM
JDM_teh_WIN!!'s Avatar
Default Re: iat sensor location
In the intake manifold is better. So if you can plug the hole on the intake arm and get a new IAT sensor for the manifold I would do that.
Old Mar 14, 2012 | 06:41 AM
MRGRIM's Avatar
R.I.P. Mark
put it in the correct place to suit the motor and ecu
then the ecu knows what its reading as it was programed for ..
move it to another location will upset the tune of the ecu as its not reading the same as the ecu is used to
Old Mar 14, 2012 | 07:10 AM
BryanM.'s Avatar
Resident Gearhead
This is my feeling too.
It may not matter, but go with what you know works.
Old Mar 14, 2012 | 07:37 AM
It's actually a better design and almost all Hondas/Acuras use it except the civic. On a civic the IAT sensor is located before the valve cover breather inlet to the intake arm. The valve cover breather allows oil vapors to mix with the intake air. On the civic the reading is taken before the valve cover breather inlet so it is less accurate. Also it is more prone to leaks.
The stock ECU is capable of making adjustments if any are needed.
Old Mar 16, 2012 | 05:44 AM
thanks guys im going to put it in the manifold
Old Mar 16, 2012 | 08:32 AM
Arthas's Avatar
I dont think the wire will reach all the way to the manifold.
I would leave it on the intake arm like Honda intended for the B16A2.
Old Mar 16, 2012 | 03:00 PM
GRIM516's Avatar
x2
madcrossover
Feb 12, 2007 08:03 PM
str8JDMteggy
Oct 23, 2006 12:57 PM
Emoson
Aug 10, 2004 05:35 PM
