Odometer doesn't work but everything else does.
My odometer is stuck right between 119,999 and 120,000. Either a coincidence or someone was trying to roll it back and failed. But everything else works fine. The speedometer might show a little faster than what I'm going (about 5mph faster) but I'm not sure since I just got the car. What could be the problem?
Should I just go ahead and get a new gauge? And if I do, which one can I get? I have a DX model with manual transmission and it has a tachometer.
Location: Pensacola, FL and every Court House in Louisiana
Re: Odometer doesn't work but everything else does.
You could take it apart to see if the gears are stripped or if something is stuck? You can replace the entire cluster from another 5 speed (any really si/ex are going to have a higher redline) or you could just get the speedo gauge from a car in the junk yard and throw it in.
I took mine apart before buying another one and it turns out that one side of that rod that holds little sprockets was out of place. I clicked it back in and everything started working perfectly.
Ash983
Honda Civic (2001 - 2005)
07-08-2015 11:00 AM
