vtec solenoid wire?
Old Mar 13, 2012 | 07:58 AM
scerbz's Avatar
Default vtec solenoid wire?
in my 93 del sol, i have a d16z6, it was wired before, but had to pull it and fix some stuff, and now i have no clue where the vtec solenoid goes in to the wiring harness.
Old Mar 13, 2012 | 08:01 AM
Dc4LsTeG's Avatar
EK9
Default Re: vtec solenoid wire?
Do you have a vtec harness? You can put it to the ecu
Old Mar 13, 2012 | 08:08 AM
scerbz's Avatar
it was wired into the harness in the first place, but it accidentally pulled out when i picked the motor out. so idk where its supposed to go?
Old Mar 13, 2012 | 08:09 AM
scerbz's Avatar
good job not paying attention right? geeze
Old Mar 13, 2012 | 08:12 AM
Dc4LsTeG's Avatar
EK9
Was it a stock vtec harness? Or was it just wired into the harness to make it "look" stock
Old Mar 13, 2012 | 09:52 AM
delsol242's Avatar
its just a simple on wire set up on my 93 its was green/yellow and just look up pin out for ur ecu
Old Mar 13, 2012 | 12:34 PM
scerbz's Avatar
pretty sure its the stock harness, i could be wrong, but like i said, the wire pulled out of the harness. so it could have been added. if i were to rerun it, where do i hook it up?
if its stock, where should it hook up? just an indicator/pic would be awesome.
Old Mar 13, 2012 | 02:27 PM
delsol242's Avatar
http://www.hondacivicforum.com/forum...rmation-73241/
check out this link it will tell you and has all the pics
Old Mar 13, 2012 | 02:35 PM
hannslebo's Avatar
Vtec solenoid is A4...(on the biggest connector at the ECU)
You can run it straight from the solenoid connector to the ECU if you don't want to put it back in the harness.
Old Mar 13, 2012 | 02:38 PM
hannslebo's Avatar
http://hondaswap.com/general-tech-ar...re-vtec-40811/
Old Mar 13, 2012 | 02:53 PM
scerbz's Avatar
somewhat helpful, but i really want to put it back into the harness where it came from, anyone able to help with pics of where it wires into the stock harness?
Old Mar 13, 2012 | 03:01 PM
hannslebo's Avatar
That link I sent you...it shows how...
Old Mar 13, 2012 | 04:59 PM
scerbz's Avatar
i get that it shows how. i AM NOT looking for how. just where its supposed to be wired into the stock harness, as if it were still stock and didnt get ripped out on accident. so i can see if i can put it back where it belongs and not have to run a new wire.
Old Mar 13, 2012 | 05:11 PM
hannslebo's Avatar
http://hondaswap.com/hybrid-eg-ek-dc...sr-swap-82462/
see if this one helps any....
Old Mar 14, 2012 | 03:12 PM
scerbz's Avatar
Got it sorted. Now to change the iat sensor, and then onto the disc brake swap out of dc2
Old Mar 14, 2012 | 03:14 PM
scerbz's Avatar
I peeked through all of them and didn't quite see what I was looking for, but thanks for the help.
Old May 17, 2024 | 01:51 PM
planchita.40's Avatar
Old May 17, 2024 | 01:55 PM
Originally Posted by hannslebo
I need your help. I want to connect my vtec 93 Honda Civic DX I can do it. I don't know do it you wanna call me and talk to me I'll pay you.
egkiller94
Dec 20, 2010 01:34 AM
Lude-venom
Nov 5, 2008 07:18 PM
FRKWOO
10
Sep 26, 2008 07:45 PM
GreddyCivic7
Feb 10, 2007 03:35 PM
Mr. Roboto
Dec 10, 2006 06:59 PM
