help neg. battery terminal
Old Oct 10, 2002 | 02:31 PM
wannab20hatch's Avatar
Default help neg. battery terminal
where does the neg. battery terminal bolt onto the engine at? doin auto to manual now need to hook battery back up.
Old Oct 10, 2002 | 02:38 PM
djay86's Avatar
Default Re: help neg. battery terminal (wannab20hatch)
im not sure whats its called but its either near or on the transmission
Old Oct 10, 2002 | 05:48 PM
keithv's Avatar
Default Re: help neg. battery terminal (djay86)
there is a bracket that sticks out near the starter that you connect the wire to.
Old Oct 10, 2002 | 05:49 PM
MrTodd's Avatar
Default Re: help neg. battery terminal (breaka_1_9)
It's the clutch cable bracket located on the tranny. Make sure the ground is also connected to the chassis.
Have fun.
Old Oct 10, 2002 | 07:13 PM
MADEINIRAQ's Avatar
Default Re: help neg. battery terminal (MrTodd)
Have fun.
what he said
but on the chassis part.. make sure the valve cover ground wire is going to the chassis
Old Oct 10, 2002 | 07:23 PM
MrTodd's Avatar
Default Re: help neg. battery terminal (madeiniraq)
While your at it, make sure the thermostat housing ground wire is connected also!
I think those are the only 3 grounds... Negative battery to chassis and tranny. Valve cover to chassis (oops, said tranny at first). Wiring harness to thermostat housing - oh wait! There's another ground wire that connects to the starter motor I think.
[Modified by MrTodd, 9:24 PM 10/10/2002]
Old Oct 12, 2002 | 10:15 AM
MADEINIRAQ's Avatar
that wire is the positive battery cable.. no ground.. you are correct on the other 3
obuhmyuh
13
Feb 11, 2008 05:44 PM
jizzer671
Dec 9, 2006 08:09 PM
pinecone
May 23, 2006 11:56 AM
EF4lyfe
Aug 28, 2004 08:36 PM
96b18c
Jun 3, 2004 07:29 PM
