98 Civic EX - bubbling noise? coming from front passenger wheel area
Old Mar 11, 2012 | 06:36 PM
brettnahmann's Avatar
Default 98 Civic EX - bubbling noise? coming from front passenger wheel area
about the noise, picture putting a very small nail into your tire, and putting a couple of drops of water over the hole...
well it happens only so often, and its definatly from the tranny area. its relative to my car's speed because if i shut the car off and roll in neutral, i could still hear the noise. I don't think it has anything to do with an engine leak, and my wheels dont have any play ruling out the bearings. im stumped...what do you got honda tech?
Old Mar 12, 2012 | 04:31 AM
MRGRIM's Avatar
R.I.P. Mark
Default Re: bubbling noise? coming from front passenger wheel area
record the sound post it up
you might be suprised people will be able to help
Old Mar 12, 2012 | 04:33 AM
grumblemarc's Avatar
The Grumpiest
You don't get bubbling noises from mechanical parts. That's coolant. Bleed the air from the cooling system for starters.
Old Mar 12, 2012 | 06:47 AM
idk how i can record the noise. its not loud as hell but its def there. il see what i can do
replaced my rad about a month ago so i bled the coolant that day, and made sure no air in the coolant the next day so i can pretty much rule that out
Old Mar 12, 2012 | 07:48 AM
The Grumpiest
I don't think that you can and to verify it will only take you maybe half an hour of your time. The cooling system is the only system where you will hear "bubbling" noises. That is, unless you have described the sounds incorrectly.
Old Mar 12, 2012 | 11:28 AM
motegicivic's Avatar
Are you sure you do not hear from behind the dash, I get that noise, might be air still trapped.
Old Mar 12, 2012 | 11:30 AM
Former User's Avatar
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Old Mar 12, 2012 | 12:10 PM
MySickSi's Avatar
Is your rad fan working? When my rad fan stopped working my coolqnt overflow was bubbling because the coolant was hot
Old Mar 12, 2012 | 07:15 PM
will do.
98 civic EX
D16Y8
i think you read my post incorrectly because i bled the system when i replaced my radiator, and the next day to make sure there's still no air that could've snuck in. if you push my car down the street while its off, you hear the noise. i think it has something to do with a moving part attached to the axle. not my coolant.
it sure is working. and the noise is relevant to how fast my car is rolling.
Old Mar 13, 2012 | 04:02 AM
The Grumpiest
Then please tell me how a mechanical part can make a bubbling sound?
Afrowookie
May 2, 2019 03:51 PM
bobbyj59
Honda Civic (2006 - 2015)
Apr 28, 2015 09:43 PM
Arman Sesar
Transmission & Drivetrain
Jun 28, 2013 03:18 PM
shane2121
Jan 19, 2013 12:31 PM
iadubber
Feb 7, 2003 01:14 PM
