b16 in eg8 no start probem
Just put a b16a from HMO in my 92 civic...used the dx harness (haven't wired vtec yet)
But...the car wont start - getting fuel/spark/air - spark is white with a little orangeish tint
All grounds checked and double checked
Even swapped distributor with a known working one...
Checked all fuses.
Using p30 ecu
Here is the kicker....
Its making funny noise...not like a a regular engine trying to start...its like a spinning/whining noise.
We tried a roll start - still nothing.
Ill try to get a vid and post it...
Any help/suggestions would be great!
THANKS.
Checked all fuses.
Using p30 ecu
THANKS.
21 - vtec spool solenoid & 41 - o2 heater....Yeah I don't think those would cause anything like you're describing.
I've never experienced anything like this...assuming everything is plugged up right and you're getting the 3 things an engine needs to run. And all your grounds are connected. Maybe someone else will chime in that has experienced this.
honda305
Sep 10, 2010 07:30 AM
ek_b16
Sep 7, 2005 10:35 AM
RussHondaCRXVtec
Dec 17, 2003 10:40 PM
RussHondaCRXVtec
Dec 16, 2003 09:37 PM
