Touchy Takeoff
If I give a little "too much" gas when taking off from 1st gear the front end seems to bounce, almost as if the tires are trying to spin or something. Could this be caused by the tires hitting the fender in the front when the tires spin a little, as the car does sit crazy low?
Other thoughts I have had would be possibly an engine mount? But seems like I would know for sure if a mount was broke.
IDK... Any input out there?
Er what? I don't know about you but when you let up the clutch and DO NOT give it gas the car will die. Now if it's an automatic that's a different story.
Get under the car and inspect tie rods, bushings and ball joints.
As far as letting off the clutch too fast, you barely have to let off the clutch as it is to engage the gear, it just seems like there is a pretty fine line between a smooth takeoff and the "wheel hop" (if thats what it is) when it comes to the accelerator pedal.
0.o
swizz977
Aug 31, 2010 08:24 PM
PePpeRedDc5
Apr 20, 2005 06:36 AM
