EG HB Project-Auto to 5 Speed
Old Mar 10, 2012 | 06:55 PM
Johncivic3's Avatar
Icon2 EG HB Project-Auto to 5 Speed
Update:
I have 94 EG HB Shell that was Auto... I am now putting in a Turbo B18B
Can anyone help me with the Reverse Light wiring and the neutral safely.
and the right way to wire up the clutch.
Pictures would help a lot.
And can anyone tell me the best / cheapest ECU to go with that will aloud me to run turbo, plug and play with the boost controller
The car has a ODB1 body harness and the motor is a B18B OBD2.
Old Mar 11, 2012 | 05:40 AM
vitamin_c95's Avatar
Default Re: EG HB Project-Auto to 5 Speed
the tranny swap is straight forward. Obviously you need all the 5 speed parts. Only electrical areas are figuring out the neutral safety as the car will think its in whatever gear the selector switch is left in, wiring in reverse lights, and unlocking the steering wheel.
Old Mar 11, 2012 | 06:54 AM
NVturbo's Avatar
O.G. triple O.G.
*auto-->manual tranny mount
*wire up the VTEC components for the motor
*as for the S2000 gauge clusters, there's plenty of DIY threads that can help you tackle that project
Old Mar 11, 2012 | 07:37 AM
beat me to it...came back to post the custom mount. Was outside pressure washing my engine and saw it
Old Mar 11, 2012 | 10:06 AM
Johncivic3's Avatar
Thanks...I found some other threads that dive into it a little.
The car had a D15 Non-VTEC Auto..but that was removed.
So far I have B16a w/ trany and the shift linkage.
waiting on a few more parts...Would it be easier to replace the stock harness with a SI harness?..
S2000-I seen this,
https://honda-tech.com/forums/showth...=s2000+cluster
Old Mar 11, 2012 | 11:34 AM
NVturbo's Avatar
O.G. triple O.G.
No need to source another engine harness if yours is still good. Wiring up VTEC is easy if you're handy with a soldering pen/gun. You can add the wires onto the old DX harness when it's out of the car. It gives you more room to work with.
Replace the following while the "new" swap is still laying around:
- clutch
- water pump
- timing belt tensioner
- front & rear main seals
- thermostatt
Ahknodd
May 18, 2009 05:17 PM
jb07_
May 5, 2009 05:26 AM
slacks
Feb 7, 2008 12:51 PM
eg ferio
Nov 29, 2003 06:20 PM
