Coolant temp fan switch not grounded??
Old Mar 10, 2012 | 01:07 PM
maglites94's Avatar
Default Coolant temp fan switch not grounded??
I installed the third motor in my civic today came to the conclusion that the fan was not turning on. Replaced the fan switch started the car when it reached 210 degrees f, i shut it off. (fan did not come on)so i grabbed the test light and attached it to the ground for the battery and poked into the green wire for the fan switch it completed the circut and the fan turned on. WTH. So does that mean the switch is not grounding?? Thank for the help.
Old Mar 10, 2012 | 07:40 PM
motegicivic's Avatar
Default Re: Coolant temp fan switch not grounded??
Jump the connector to see if the fan runs, turn the key to the 2 position.
f15Civic
Mar 9, 2017 05:45 AM
prodjay10
Mar 4, 2017 07:21 PM
kai-chun
12
Sep 8, 2006 03:20 PM
ATS*Mark
Dec 9, 2003 11:08 PM
