Misfire, high NOx
Old Mar 10, 2012 | 12:55 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Icon6 Misfire, high NOx
1998 civic EX, auto, stock, 180k miles.
part throttle causes occasional misfire, i attributed to a cracked exhaust manifold, which i had replaced. the misfire continues. ca failed SMOG with high NOx.
ideas? clogged injectors? bad cat?
Old Mar 15, 2012 | 11:10 AM
Default Re: Misfire, high NOx
going to run some injector cleaners and see if the missfire goes away. my thought on that is lean mixture causes high NOx levels due to clogged injectors.
Old Mar 15, 2012 | 11:32 AM
98civdx's Avatar
Master Detailer
How long were you driving with the cracked manifold? You can kill the o2 like that.
Have you checked the timing? What about plugs/wires?
I just looked around for a minute, and found someone in cali with High NOx issues. He replaced cat/o2, ran seafoam, retarded the timing, etc. At the end he swapped the o2 for another one and it passed.
Old Mar 15, 2012 | 04:05 PM
motegicivic's Avatar
Check your plugs, if you were running rich you could of fouled them.
Also, reset your ECU, since you have a new exhaust mani.
Also, check your primary O2 or should of when replaced the exhaust mani.
Old Mar 15, 2012 | 05:27 PM
Former User's Avatar
CEL codes?
When was the fuel filter last replaced? Have you measured the fuel pressure and tested the FPR?
Is the problem eliminated by unplugging the O2 sensor?
Old Mar 17, 2012 | 09:48 AM
the plugs are fine, the car if anything was lean. there was a general misfire code, which went away. have not replaced the filter, nor the O2 sensor, rather not, if not needed.
Old Mar 17, 2012 | 09:49 AM
the NOx was marginally high, just a few points above. if that makes any difference.
Old Mar 17, 2012 | 10:00 AM
98civdx's Avatar
Master Detailer
Check the ignition timing?
Old Mar 17, 2012 | 10:11 AM
Timing is within spec.
krazy_23
Feb 2, 2016 10:18 PM
gnxpro24
Dec 15, 2014 04:30 PM
StuckInTexas
Nov 8, 2012 07:55 AM
Magick211
Oct 28, 2006 02:51 PM
alotawatts
Sep 20, 2004 03:24 PM
