K series oil pump?
You may have a couple of choices. One you can buy an S2000 modified for k20 pump. Get your k20a2 pump ported. Increase your oil return spring pressure and that might give you what you need.
Stefan
Stefan
Call Sean @ ERL and their kit, simple and works like a charm... I would also recommend using the Accord Aluminum oil pan, has better clearance for the oil pick up then the steel K24 oil pan.
ACCORDingly94
Engine Machining & Assembly
Oct 2, 2015 12:28 PM
boredracer408
Aug 10, 2007 12:55 PM
