Aftermarket header B16 - Check Engine Light.
Old Mar 9, 2012 | 11:23 AM
omaralbasri1's Avatar
Icon2 Aftermarket header B16 - Check Engine Light.
I installed an aftermarket performance header in my 2000 Civic 4D. no problems, beautiful sound, better gas mileage, however my first O2 sensor broke on me and I had to throw it away, so I took another O2 sensor from 99 Civic Hatch installed it but the Check Engine light is still on. Sometimes when I hook it to the check engine device it gives me sensor 1 and/or sensor 2. Sometimes the RPM go down below normal and you feel little shaking.
Any ideas? I already resetted the Check Engine more than one time but same issue. Should I get O2 sensor for civic exclusively?
Old Mar 9, 2012 | 01:23 PM
dpetro1's Avatar
Default Re: Aftermarket header B16 - Check Engine Light.
what exact CEL code is being triggered?
Old Mar 9, 2012 | 07:11 PM
O2 sensor bank 1 sensor 1, or sometimes bank 1 sensor 2. It's really confusing. I want to turn off the CEL by anyway but of course not by disconnecting it.
Old Mar 9, 2012 | 07:43 PM
purgat0ry's Avatar
Pull the O2 sensor and give it a good scrubbing, make sure all of your wires are seated in the plugs properly, try it again.
Old Mar 9, 2012 | 08:13 PM
Already did that. Cleaned them also with the air compressor thingy and it didn't work. I removed both of them and went for a drive, the idle like it's going to die. Then I put the O2 sensors back again and same thing nothing changed. Btw the header I bought doesn't come with Cat Converter, which I don't really think it has something to do with the O2 sensors.
Old Mar 10, 2012 | 04:32 AM
BryanM.'s Avatar
Resident Gearhead
02 sensors need a solid ground connection, make sure they are grounded well.
A P0420 will pop up without a cat converter.
Old Mar 10, 2012 | 06:01 AM
O2 sensors are plugs. Where is the ground for them?
Is this the same as the O2 sensors 1 and/or 2?
Old Mar 10, 2012 | 05:06 PM
And I was thinking about getting new exact same O2 sensors.
Old Mar 11, 2012 | 05:00 PM
dpetro1's Avatar
Instead of the CEL description. Please give the numerical code(s)
Old Mar 11, 2012 | 06:06 PM
I will when I go to the garage next time. Thanks for the responses.
Old Mar 11, 2012 | 06:15 PM
HondaPartsHero's Avatar
Technical Hero
Your title is confusing, is it a B16 or D16? The B16 doesn't have the cat built into the header the D16Y7 does. Where does the new header have the O2 bungs at? Can you take a pic?
Old Mar 11, 2012 | 07:02 PM
It's D16Y7, really sorry about that. The problem is I threw the old header away. This is exactly what it looks like http://i40.photobucket.com/albums/e2...exhaust062.jpg
Old Mar 11, 2012 | 08:28 PM
Here's a suggestion, I can buy a direct fit cat converter, fit it and weld it if it needs to. It'll come with an O2 sensor bolt. I think this is a probability that it might turn off the CEL off. What you guys think?
skuba
Engine Management and Tuning
Jan 18, 2010 05:45 PM
DailyDriven259
Aug 31, 2009 04:54 PM
Themouse
19
Feb 1, 2006 04:17 PM
