Advancing Ignition Timing after ECU tuning
Old Mar 9, 2012 | 06:24 AM
redred1188's Avatar
Icon3 Advancing Ignition Timing after ECU tuning
had an ecu tuning just last week. yesterday, i tried advancing the ignition timing (via distributor). i advanced it 4 degrees more.
pull is greater now, in fact its pulling much better after i advanced the distributor. and there is no detonation.
my question is, the fact that the ecu was already tuned, will it affect certain things? like lets say fuel economy etc. or is it ok, as long as there is no decrease in power?
power is much better now after i advanced the dizzy, thats why im asking can i keep it this way or should i return it back.
it was on 12 degrees adv when it was tuned, and i adjusted it to 16 degrees ADV now.
Old Mar 9, 2012 | 06:38 AM
HRTuning's Avatar
Default Re: Advancing Ignition Timing after ECU tuning
Nobody can tell you whether it's ok to advance more with your tune except your tuner. If you want to make adjustments I'd suggest doing so in the ECU so you can actually see the values. Advancing it 4 across the board may help your low end if it was conservative and hurt your top end if it was aggressive, for example. Good luck. And yes it can effect air/fuel, so if you don't have a wideband don't do it.
Old Mar 9, 2012 | 07:19 AM
redred1188's Avatar
is fuel consumption going to increase due to me advancing the dizzy? would it be better if i just put it back to where it is.
Old Mar 9, 2012 | 07:39 AM
HRTuning's Avatar
JohnnyEF
Feb 10, 2010 06:09 PM
ChevelleSSLS6
Nov 13, 2009 09:06 PM
---SPEED-DEMON---
Engine Management and Tuning
Apr 1, 2009 12:14 AM
wilsel
Mar 23, 2005 05:37 PM
DutchITR1689
Oct 12, 2004 01:17 PM
