new motor or new head gasket
Old Mar 8, 2012 | 05:49 PM
BertDog's Avatar
Default new motor or new head gasket
My car needs a new head gasket for my jdm b16 pr3-2. I found a b16 replacement for a 2000 civic si. Do u think I should buy the head and block or just replace my head gasket. I'm so nervous about this I need some really good advice. Also a good Honda mechanic in lake Charles, la.
Old Mar 8, 2012 | 07:47 PM
seanbev24's Avatar
Default Re: new motor or new head gasket
Head gaskets are easy on B series engines, so it's worth fixing IF the motor is in otherwise good condition. If there are other engine problems, a ton of miles, driven a long time with the bad headgasket, then you'd be better off just replacing it with a new longblock.
Old Mar 9, 2012 | 05:34 PM
BertDog's Avatar
I now its easy everyone says it is but im used to working on chevys and when you start taking cams out its ludacris. Are takeing the cams out that easy. I just dont want to mess anything up any worse. lol
Old Mar 9, 2012 | 07:05 PM
mudpuppy4life's Avatar
taking cams out are almost as easy as a 350 just take a hand full of bolts out and lift the cams out where a v-block you slide em out
Old Mar 11, 2012 | 08:49 AM
BertDog's Avatar
Let say I do this should I replace any of the csm bearrings or have a valve job done.
Old Mar 12, 2012 | 01:59 AM
seanbev24's Avatar
There are no replaceable cam bearings on these engines. If the cam journals are screwed up you need a new head (rare). If they're not leaking, I'd personally leave the valves alone and just have the head milled for flatness.
Follow the manual for torque specs and sequences and there's nothing to worry about.
jdmkidd23
Feb 17, 2010 12:46 PM
jdmkha
Nov 4, 2009 07:35 PM
z0om
Aug 28, 2008 04:12 PM
boomersz
10
Apr 11, 2007 04:37 PM
Crackerballer
Dec 30, 2003 01:04 AM
