HEAD GASKET CHANGE STEPS
I DID EVERYTHING THAT IS NEEDED BUT I AM STUCK ON THIS PART. I TOOK MY CAMS OUT,UNBALTED THE HEAD,REPLACED THE GASKET, REBOLT THE HEAD. NOW.....I ORDER TO GET THE CAMS BACK INTO SPEC DO I NEED A FEELER GAUGE.....OR WILL THE CAMS ALREADY BE AT SPEC..........
PS, I DIDN'T CHANGE THE CAMS THEY ARE THE EXACT SAME ONES
They are going to be the same, I don't know how many mileage you have or when was the last time you adjusted your valve lash. But it might be a good idea to adjust them while your at it.
schumi
Jul 21, 2008 04:06 PM
