Car dies when pulling spark plug boot.
Old Mar 8, 2012 | 10:27 AM
Schultzie's Avatar
Default Car dies when pulling spark plug boot.
Any idea what would cause this. the car has a rough idle. Already replaced plugs, wired, distributor. Any help is much appreciated.
Old Mar 8, 2012 | 10:41 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Car dies when pulling spark plug boot.
While it's running? Are you retarded or something? DO NOT DO THAT!
How about you tell everyone WHY you are pulling spark plugs in the fist place. Better list all the car details if you don't want your thread locked.
Old Mar 8, 2012 | 11:33 AM
NVturbo's Avatar
O.G. triple O.G.
OP, are you drunk? Geez.
Hey grumblemarc....I wish I can make my sig in large fonts. Some people love to do stupid **** to their cars.
Old Mar 8, 2012 | 12:17 PM
dascivic96's Avatar
your pulling the plug boot, off the spark plug, while the car is on..?
is that what your saying?..
Old Mar 9, 2012 | 07:17 AM
gold_pwr_r4ng3r's Avatar
why would you pull the spark plug boot out while the car is running....
Old Mar 9, 2012 | 10:03 AM
purgat0ry's Avatar
Some people do it to verify they are getting spark still; generally it's pulled from the dizzy side, NOT the actual plug side.
Though it is still a bad idea.
Old Mar 9, 2012 | 11:54 AM
omaralbasri1's Avatar
Clean O2 sensors and CHANGE the coolant fluid. It worked for me.
Old Mar 9, 2012 | 12:00 PM
JuggerNaut-CTR's Avatar
lol
Old Mar 9, 2012 | 12:01 PM
For the rough idle...clean the iacv, fitv, and iat sensors. More likely than not will fix the idle.
Old Mar 9, 2012 | 02:06 PM
MRGRIM's Avatar
R.I.P. Mark
for all the noobs above that dont know OLD SKOOL WORK.
this method has been used for decades to determin the spark plug/lead at fault
that is causing the bad idle or miss
If your trying to fault find as to what one is the cause and it keeps dying
raise the idle a bit and try again
if you remove a lead and it stalls thats not the problem
restart with all leads on and move to the next lead
to know when you have a bad lead or plug it will keep running with minimal change
if after all 4 have been tested this way with out change your fault is else where
mmmm ask me how i know..race engine builder over 20yrs
Old Mar 9, 2012 | 02:14 PM
LSVTAK_EK's Avatar
^^^ that was good!
Old Mar 9, 2012 | 03:00 PM
The Grumpiest
Usually when you do it on Hondas you could blow the coil.
Old Mar 9, 2012 | 11:09 PM
dascivic96's Avatar
theres more ways to check for spark than just unplugging the boot with the engine running. if that is what you were trying to get from doing that
702SI
Dec 5, 2014 03:59 PM
ravinaziankid
Aug 14, 2012 05:25 PM
sfr4dr
Jan 19, 2004 03:53 PM
Mefain
Jun 3, 2003 10:15 AM
