CEL Del Sol 94'
Old Mar 8, 2012 | 05:58 AM
hacker4991's Avatar
Default CEL Del Sol 94'
When i checked my cars CEL using the ECU wire trick, and i got code 9 which is CYP - cylinder sensor
What does this mean for my car?
Old Mar 8, 2012 | 07:31 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: CEL Del Sol 94'
Is it running bad? If not clear the code and see if it comes back. If it is running bad you're more than likely going to need a new distributor.
Old Mar 8, 2012 | 08:47 AM
hacker4991's Avatar
I mean it doesn't run bad, it runs great. How would i clear the code?
Old Mar 8, 2012 | 09:41 AM
dpetro1's Avatar
pull out the ecu fuse or disconnect the negative battery cable
Old Mar 9, 2012 | 05:49 AM
hacker4991's Avatar
Okay so i did that then, code still pops, so its the distrubitor?
Old Mar 9, 2012 | 10:34 AM
Stoodybayker's Avatar
I'm having the same problem with a CEL code 4. Changed distributor AND ECU..no dice. I'm thinking (because the car DOES run great), that it might be an intermittent wiring error.
onytay06
Feb 22, 2018 03:57 PM
stc876
Oct 2, 2013 10:53 PM
krisfnbs
Mar 17, 2011 04:58 PM
Mr.Death
Oct 11, 2008 11:15 AM
HOUSTONtx
Jul 10, 2008 01:02 PM
